1996 Chevrolet Cavalier Logo
Posted on Oct 11, 2008
Cavalier convertible rearview mirror fell off
Could someone please tell me how I can put the rearview mirror back on the windshield of my 96 Cavalier convertible? It just fell off while I was at the vets with my cat. The car only has 22,000 miles on it; I guess the glue dried up because it wasn't bumped. It has the wire for the front reading lamps attached and still working. I noticed a metal piece on the back of the mirror's stem...
anyhow, help, please! Tracy
  • pboxer57 Oct 11, 2008
    Thank you for your help! I really appreciate it!
Anonymous
Level 1:
  • Contributor 32 Answers
  • Posted on Oct 11, 2008
Anonymous
Contributor
Level 1:
Answers
32
Questions
0
Helped
19290
Points
98
There is a screw that holds that piece of metal in place. take the screw out and remove the piece of metal then look at a local hardware or automotive store and ask for the windshield adhesive. and fallow that instructions pay close attention to the temperature to be applied at and the Harding or drying time.
We have a 2004 Hyundai Sonata. The inside rear view mirror fell off and glued back a few year ago. It fell off again a few days ago and it dragged off a piece of windshield glass with it. Now there is a...
windshield's are made of laminated glass so they shatter into tiny pieces when in an accident so do not cut as bad , the rearview mirror has pulled the first layer of laminate away , the windshield will be weakened by this and could shatter at any time , particulary over rough/bumpy ground, it cannot be repaired so you will need to replace the shield , as for who designed the mirror he wasn't very clever !
How do i reattach my rearview mirro on my 2005 kia sorento. the attachment is on window but mirror was knocked off.
My name is Elsie and I have a 2003 kia Sorento and my rear view mirror fell off my windshield how do I put it back on
My rearview mirror fell off and im having problems putting it back on without the metal button/bracket/mount that suppose to be there.
when your mirror fell off the metal bracket stood with the mirror
unscrew it
there a special glue for fix it on windshield
1helpful
I have a 2000 buick regal. the rearview mirror fell down. How do i get the metal piece out to reattach to the windshield?
should just be a torx 15 also t15 screw driver to unscrew it and u must use the rearview mirror adhesive sold at most parts stores
2answers
How do you reattach the rearview mirror on a 2001 tacoma Thanks
get a rearview mirror glue kit and follow the instructions.
2helpful
2answers
Having trouble replacing rearview mirror on 96 buick park avenue
you usually dont...it is installed on the windshield at the manufacturer using a super hard epoxy.
Chevy S10 Rearview Mirror glue sticks, but temporarily
At this point, I'd take it to a glass shop that does windshields and let them try the commercial adhesive.
2answers
Rearview mirror fell off windshield
there is a small allenwrench bolt in the mirror back out the bolt and install then tighten back up
Custom Rear view mirror
Hiya...ALL factory-installed rearview mirrors are installed with different wires due to options.
About 6 different rearview mirrors are installed with those options such as On-Star, light, compass, and those features which use different wires....THIS CANNOT be modified with different rearview mirror....**for example, the Equinox owner attempt to pull out a factory-installed base rearview mirror and put in different one that has compass/temperature built into the rearview mirror**
However, the wires are located inside the front headliner which requires removing the sunvisor (and possible removal of interior plastic trim part at the left/right ends of the windshield) prior to pull the headliner down, and a small metal philips or torx screw is used to secure the rearview mirror onto the bracket glued to the windshield.
The best solution is to leave the original factory-installed rearview mirror in place.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
