Scale will not reset keeps reading 0.0 lb
Well I figured it out, just in case anyone comes across this. Turn it over, push the button on the top middle of the scale, hold, turn back over, wait until "C" appears on the screen, stand on scale, now it works. :)
Posted on Jun 01, 2016
SOURCE: weight watcher scale not calibrating weight correctly
Hi there;
Flip the scale over and see if the switch is on kg or lbs. If it is on kg, switch it over to lbs and see if that fixes your problem.
HTH.
Posted on Oct 05, 2008
SOURCE: Conair WW41 Scale
To totally reset the scale and remove any old data in the users take battery out for 2 hours.
To use the USER functions:
Tap scale to turn it on
When you see "0.0" press
Press SET button. "P-1" will appear and blink
Use UP/DOWN button to select a user number
once desired user number (1-4) appears press SET button to confirm
when 0.0 appears step on scale this will enter your starting weight
press SET to confirm
scale automatically sets a goal weight of 10% below starting. you can raise or lower it by using arrow buttons-Press SET to confirm
Tracking weight
tap, see 0, select user number. Scale displays start weight, then goal weight then 0.0 and you weigh yourself. In the smaller windows it will display last weight and the difference between current and last weight then diff between current and start then diff between current and goal
Posted on Dec 04, 2008
SOURCE: Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Posted on Mar 14, 2009
SOURCE: My Scale stoped weighing me, now it reads 1-ld .
The sensor has been worn out or has been pushed past it's weight limit. When you get on it, it pushed the sensor past the point of working... When she gets on it, no problemo...
Posted on Mar 16, 2009
SOURCE: resetting the scale
You do not reset the scale. It only saves the last recorded weight of the user. So, if you weighed yesterday, it will put your recorded weight in memory. The next time you select your user number and step on the scale, it will compute the difference from your previous record and save your current weight.
Posted on Mar 25, 2009
May 05, 2016 | Health & Beauty
Mar 26, 2016 | Health & Beauty
Mar 04, 2015 | Taylor 7506 Precision Tech Lithium Battery...
Mar 03, 2015 | Health & Beauty
Oct 13, 2014 | Health & Beauty
Jun 27, 2014 | Taylor 3831bl Digital Scale 6.6...
Oct 13, 2017 | Healthometer Health o meter BFM689KD 63...
Aug 22, 2011 | Jobar International Ideaworks Remote Read...
Jun 12, 2011 | Homedics Digital Scale
Jan 15, 2018 | Taylor Biggest Loser 7206 Electronic Cal...
Jan 30, 2013 | Taylor Biggest Loser 7206 Electronic Cal...
644 people viewed this question
