SOURCE: My LG Combi Microwave oven
This is usually caused by either a bad door switch (usually the top one), a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: Want a user manual of a microwave oven
L.G. / Goldstar owner's
manuals can be downloaded here.
If it doesn't show up in the search, I would call or e-mail them via the CONTACT US link at the top right.
We're
happy to help you with free advice and we'd appreciate your
SOURCE: MICROWAVE LG MODEL MC-806BL LAMP BLOWN
If
there's no obvious removable cover over the bulb (most often on the
rear or side) and the owner's
manual doesn't address it, then disassembly will be required.
Always unplug a
microwave before removing or installing any bulbs.
If
it's an over the range type, remove the vent grille across the top and
see if bulbs can be accessed there. There may be a panel on the bottom
covering the light(s), instead.
If not, chances are
you'll have to remove it from the wall, then remove the outer cover. If
so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
Once it's out of the
wall, the outer cover (wrapper) will need to be removed, just as you'll
need to do on a counter top model.
On a
counter top model,
be sure it's unplugged, but otherwise ignore the instructions
above this paragraph.
The
screws you need to remove should be pretty obvious, but a special
driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the
screws back in the right holes, since some may be special grounding
screws.
Bulbs can be had in most
grocery stores, hardware stores, home improvement centers, and big box
or department stores.
Many models use halogen
lamps. You must not touch the new one with your bare skin, as the oils
will shorten the bulb life.
In the UK, LG customer support is here. You may find your owner's manual online here.
We're
happy to help you with free advice and we'd appreciate your thoughtful
