Question about Apple iPod Photo MP3 Player
SOURCE: Frozen Ipod
what you can do, is take the hold button, and push it back and forth maybe 2 or 3 times, than you hold down the "menu" utton and the center button at the same time for about 10 seconds and you will see it restarting with a black screen and the apple icon in the center than you can let go of the buttons and about 10 seconds it willl become brighter and you will see the icon, then you can get to all of your music or videos and such
Posted on Mar 30, 2008
SOURCE: apple ipod 20gb
Try a reset:
How to reset iPod To reset an iPod with a Click Wheel, including:iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation)iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds.
You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Hope this helps
check out my blog at:
http://www.pchelpforanyone.blogspot.com
Posted on Apr 03, 2008
SOURCE: ipod shows sad face and folders
the sad face means there is a software / hardware side fault witch needs service.
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore…
www.apple.com/support/ipod/five_rs/
If they dont work you will need to send the ipod in for service.
Posted on Apr 19, 2008
SOURCE: how to insert songs/movies in 80GB apple ipod classic
Just few steps:
Please rate my solution.
Thanks..
Posted on Jan 03, 2009
SOURCE: Need users manual for Apple iPod Classic 80GB Silver MP3 Player
lost my 80gb ipod software
Posted on Feb 23, 2010
