Question about Philips GoGear HDD1830 MP3 Player
My Philips GoGear Vibe 4 GB MP3 Player is saying file system error, the pc does not recognize it and it is only charging
Posted by Maricel Ramirez... on
5 Related Answers
Anonymous
SOURCE: philips gogear 8 gb mp3 player
My guess is that you all have Vista, or an XP install with Windows Media Player 11.
Revert back to Windows Media Player 10 and fire up the Device Manager that came on the CD (You can also find it at phillips' website, in the product support section.) Click on the tab that says 'Repair' and hit the 'Repair' button. This should fix your problem.
Note that this will remove all of your files from the device.
Posted on Jun 30, 2008
shadow83
shadow83
  • 496 Answers
SOURCE: iTunes to MP3 player
your going to need a conversion program because most likely the itunes files are .acc and not.mp3 so find a nice little converter and enjoy
Posted on Sep 29, 2009
hunter19_46m
Curtis Sewell
  • 7482 Answers
SOURCE: How do you delete videos and photos from a Philips
Deleting Files,Pictures,etc from MP3 Player
Hook up your mp3 player to your computer Go to your desktop and double left click on "My Computer" When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there. Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible. Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete" Now you mp3 player should be clear of the files/songs you do not want. Good Luck, I hope this helps
Posted on Nov 28, 2009
firesnake09
Melvin Ramos
  • 2923 Answers
SOURCE: whenever i try to play
"File format not supported" means that the song that you've downloaded into your MP3 player is NOT an .MP3 file format. For each MP3 player have their own supported file formats. You need to check the manual of your MP3 player to see what are the supported sound file formats (i.e. .mp3, .wma, .mp4). Then check the file format of the songs that are saved in your player.
If the songs are supported but you're still getting the error message, try to delete all the songs and then download the songs again and save it into your player. If the same problem occur, then it may need a firmware upgrade or reformat.
Thank you and good luck!
Posted on Oct 31, 2010
Testimonial: "thanks"
Anonymous
  • 269 Answers
SOURCE: It says on the phillips
yes your correct there are different types /size of mp4 s here is a video on Philips site that explains what sizes format are acceptable usually the player comes with a disc that has a free tool to convert videos to proper sizes hope this helps and please vote
Posted on Nov 30, 2010
What does file not supported mean on my gogear vibe and how do i change it
Your Philips GoGear Vibe supports these formats:
audio
  • MP3
  • PCM
  • ADPC
  • Audibl
  • WMA
video
  • SMV
audiobook format 4.
More support info:
Philips GoGear MP3 video player SA1VBE08K ViBE 8GB
Dec 16, 2013 | Philips GoGear ViBE SA1VBE08K MP3 Player
Error code f0305023
my philips GoGear Vibe when i start file system error
error code F0305023 what i do now?
how can start this? pl. help me.
Jun 11, 2013 | Philips GoGear ViBE Digital Media Player
I am trying to download the mannual for the Philips GoGear Vibe MPS video player 8 GB serial number SA3VBE08K/37
quick start guide:
http://download.p4c.philips.com/files/s/sa3vbe08k_37/sa3vbe08k_37_qsg_aen.pdf
user manual:
http://download.p4c.philips.com/files/s/sa3vbe08k_37/sa3vbe08k_37_dfu_aen.pdf
Jun 11, 2011 | Philips GoGear ViBE SA1VBE08K MP3 Player
My gogear vibe says file system error...what do i do to make it work again?
if your PC can show the removable disk drive you should format it. In this case all the folders and media files will be erased on your player.
If the PC can not see the player you could try to make firmware upgrade.
I think, this link will help you:
http://www.userdrivers.com/MP3-Player/Philips-GoGear-SA6015-SA6025-SA6045-MP4-Player-Firmware-Upgrade-1-15-2/
bye, gylacz
Jan 10, 2011 | Philips GOGEAR SA6045 MP3 Player
My mp3 won't charge
You will probably have to perform a Repair, but start simple:
1) Reset your GoGear - paperclip into reset hole while player is turned on
2) Restart your computer
3) go to www.usasupport.philips.com and follow the frequently asked question for your SA5125 - My player is not recognized by PC
4) Repair the device: (WARNING: this will delete all files off your GoGear)
1) Backup all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new.
-Tha Mp3 Doctor
Jan 28, 2008 | Philips SA5125/37 MP3 Player
Philips GoGear HDD1830 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
aliasger yq
Jean Sintulaire
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
