Question about Oregon Scientific Wireless IndoorOutdoor Thermometer with Atomic Clock Sync
I have model RMR682--Want to disable the Alarm--Please advise
Alarm starts at 37.4 when going down and at 28.4 when increasing. I like the Thermometer and Clock, but would like to shut-off the alarm. It goes off repeatedly both up and down and is annoying.
Posted by jerry bradford on
  • lee_worma653
    lee_worma653 May 24, 2012
    The ice warning is only for channel 1. Set the sensor to a different channel (2 or 3).
lee_worma653
    New Friend:
The ice warning is normally only on channel 1. Just set wireless sensor to channel 2 or 3, then select that same channel to display on the base unit.
If you don't ever want to use the ice warning feature, then use channel 1 for a sensor that's situated indoors, then hope you never hear it!!!
Lee
Posted on May 24, 2012
I cast on 38 stitches. Directions read k 5, (KFB, knit 1) repeat to last 5 sts, knit 5. Directions say 50 sts., I end up with 53. What is wrong? Can you help?
Starting with 38 stitches, you should end up with 52:
5 + 2(14) + 5 = 38 after increasing on every other of the center 28,
5 + 3(14) + 5 = 52
However, if you start with 37 stitches, you should end up with 50:
5 + 2(13) + 1 + 5 = 37. after increasing on every other of the center 26,
5 + 3(13) + 1 + 5 = 50
Jan 05, 2017 | Sewing Machines
How do I disable or remove door alarm?
The alarm is operated by a magnetic switch connected to the control board. If you can find it you can bridge it out if it's a make switch, or disconnect it from the board if it's a break switch. Find the control board and the connection first. ***WARNING*** the switch also operates the internal fans and removal of the feature will increase your power bill and make the fans run permanently. Does the alarm come on as soon as the door is opened?
May 03, 2014 | Samsung RF260BEAEBC 26 Cu. Ft. French Door...
GA-81945GZME-RH alarm then shutdown
Gigabyte Support > GA-81945GZME-RH mobo > Main Support page,
[MOtherBOard ]
http://ee.gigabyte.com/products/page/mb/ga-8i945gzme-rh/
Click on the Downloads tab.
(Advantages / Overview / Specification / Downloads / etc)
To the right of - Download type: - click on the blue Down Arrow.
Click on Manual in the list.
To the right of the English heading, click on the country name nearest yours.
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the country name it may take up to 30 seconds, before the first page comes up.
Hover your mouse cursor towards the Bottom/Middle. The ghosted out navigation guide will appear.
Go to the far right, and click on the Adobe PDF icon.
(When your mouse cursor is on it, "Show Adobe Reader toolbar" will briefly appear )
You may have to increase, or decrease the view size.
Use the Zoom Out icon ( - ) at Top; to decrease.
Use the Zoom In icon ( + ) to increase.
Page 39 - 2.4 Power Management Setup
Scroll down a little;
Resume by Alarm
"You can set resume by alarm to be enabled, and key in Date/Time to power on system.
Disabled -> Disable this function. (Default value)
Enabled -> Enable alarm function to POWER ON system.
If Resume by Alarm is enabled,
Date (of month) Alarm: -> Everyday 1-31
Time (hh; mm; ss) Alarm: -> (0-23) (0-59) (0-59)"
Regards,
joecoolvette
Jan 01, 2013 | Gigabyte GA-EP43-UD3L Motherboard
UNWANTED VOULME INCREASE WHEN RADIO ALARM STARTS
have a look at the manual and check how to disable the radio alarm to maximum range.as i think you have set it to automatic maximum volume.
Jun 01, 2010 | Memorex MC7101 Clock Radio
1994 chrysler LHS alarm
My personal suggestion would be to go for these repair catalogs. I know this website www.reliable-store.com that i used to get manuals from, and they have all models online.
I also brought for my 1989 BMW, such old model, they
had it and it was very good manual. Go ahead, I bet.
Feb 28, 2018 | 1994 Chrysler LHS
After reinstalling my battery, the alarm, which the previous mechanic was supposed to have disarmed kicked in. He had disconnected the manual button. I found the wires wrapped under the dash, bared the...
take it back to the electrician and this time tell him not to disable the alarm but simply remove the fuse for the alarm that will disable the entire alarm system
Jan 31, 2010 | Car Audio & Video
Freezer temperature v
This sounds like your motherboard,computer or control board(they call it different things in different models) is bad. It is responsible for the fan speed and timing of the defrost cycle. To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Sep 20, 2009 | Freezers
Ice alarm
I found a web site that gave me the solution to my problem. It is now fixed!!
Mar 14, 2008 | Audio Players & Recorders
Oregon Scientific Wireless IndoorOutdoor Thermometer with Atomic Clock Sync Logo
660 people viewed this question
Top Oregon Scientific Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
