SOURCE: I have a "Dish" universal
Your post caught my attention, paulobrien1, as I found it interesting! Here are the codes for a Phillips DVD player: 925, 585, 554, 556, and 678. If you have any questions or issues with that, I encourage you to let me know so I can look into it a bit further for you!
Hope that helps!
SOURCE: My RCA remote controller stopped
Here is the direct link to the User's Manual for your remote:
http://audiovox2.info/docs/common/RCR312WR/RCR312WR_OM.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck and take care.
Joe.
SOURCE: I'm tryna program my universal rca remote
Hello To program your universal remote to control your components using the Direct Code Entry Method, follow the steps below. 1. Manually turn on the component you want the remote to control. 2. Locate the enclosed Code Lists. Find the list for the component you wish to program. Find your component's brand. You will see a listing of four-digit codes for each brand. If your brand isn't listed, use one of the Code Search methods to program the remote control. (Refer to pages 3 and 4 for Manual and Auto Code Search methods.) Note: You can also use the online code finder at 3. Press and hold the component key (TV, VCR•DVD, SAT•CBL) you wish to program. The illuminated ON•OFF key turns on and remains on. If you release the component key at any time during the Direct Code Entry procedure, the illuminated ON•OFF key blinks four times, and the process is exited. 4. While holding down the component key, consult the Code Lists for the four-digit code that corresponds to your component's brand and use the number keys (0-9) on the keypad to enter it. While you are pressing the numbers, the 5. After the fourth number is entered, the illuminated ON•OFF key turns on. At this time, release the component key. If the illuminated ON•OFF key turns off, you have entered a valid code and have followed the correct procedure for Direct Code Entry. If you enter a code number that is not in the Code Lists or you do not follow all of the steps for Direct Code Entry, the illuminated ON•OFF key blinks four times when the component key is released. This is an indication that a programming error has occurred. In that case, repeat the Direct Code Entry process from step 3. Tip: Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently 6. To confirm that the component key is programmed with the correct code for maximum functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your components do not work, try programming the remote with a different code in the list until you find the code that allows the remote to control the majority of your component's functions. Different codes can provide different levels of
Codes for Sanyo TV with RCA RCR312W remote are:
10054, 10154, 10159, 11142
www.rca.com/codefinder to find the best code for your component
illuminated ON•OFF key turns off.
programming the remote to control.
functionality
OK.
SOURCE: TO UNLOCK PARENTAL CONTROL FOR A PHILIPS 15PP9925/125
yes you can use the universal one, just follow the guard line that followes the uviversal remote
