I am trying to set upa microphone but when displaying the SPEECH folder there is no option for audio inpt as suggested in the help documentation. I am trying to set up a Skype account
To set a microphone you do not need to get to the speech folder..That folder is for other things ...
just insert the mic..and go to the control panel ..and open the sound manager ..In there select record ..and after that select the mic .
click on set default if you have only one sound card ..and not using any digital cables..and than configure...from the list select headphones or desktop mic...and go with the wizard ..It should show the signal being received and next when the progress line react on noises..
usually the mic should work right the way if it is plugged in the pink in for mic on a desktop and for laptop ..just open the speaker configuration and select headphone if it does not detect the mic..(this enables teh jack plugs for some laptops..
if you have a windows xp ..just double click on the volume icon on the bar ..and volume manager will start ..In the list look for the mic..raze volume and un-mute ..If the mic is not in the list ..click on options ..and properties..(top left ) ..and tick the mic case .This will display it and enable it ..
by the way ..after that start Skype ..and in the preferences start the device detect ..or configuration ..this will start some kinda wizard that detects the mic and the camera and let you adjust ..After that will work ..It is similar with the wizard fro call set-up in yahoo messenger..
but you still need to enable it if it is not detected.
Also make sure your sound card is installed proper ..and other sounds and such are working ..
Just read what I said before ..and follow them and will work ..The settings have to be made first in windows and after that in skype ..basically on skype you just verify if it has signal ..
