My machine is Kenmore Elite front load It is giving a loup buzz and H then F display on panel
Hello Sandra,
The FH error code means the computer on the control board didn't detect any water entering the washer..sometimes it doesnt detect the water entering because the filter screens on the water inlet valve are clogged with sediment and water is having a hard time entering the washer.
The filter screens can be checked by turning off water at the faucets and disconnecting the fill hoses from the back of the machine and pop the screens out of where the hoses connect at the washer and check for blockage in them. If they are found to be clean, check the water coming out of the hoses before connecting them back to the washer...if the screens are clean and water pressure is good out of the hoses the part of the washer called the FLOW METER would need to be replaced.
Thanks for using FIXYA.com
GENE
