OUr Electrolux EW28BS71IS fridge has suddenly stopped making ice and will not dispense water. I thought maybe the in fridge PURE water filter was blocked so I changed it. The filter fills with water when you press the dispenser lever but thats as far as the water seems to go. The filter build up enough pressure after that it pops out when you press it's release button. The ice maker has been replaced 3 times under warranty for not making ice or making wet ice but this is the first time there is no water.
First check that you have good water pressure to the water valve. If you do, then the problem is in your refrigerator. And the most likely fault is the solenoid controled water valve which is a one in two out valve. Follow the water line from you house input and the first place it connects is that valve.
Thanks I will check it out when I get home tonight.
Obviously I'm not in front of the fridge but the water line goes through a common water filter then splits somewhere between that and the ice make/ door dispenser. I don't believe it splits at the input on the back of the fridge.
Thinking it's may be a frozen line but I don't know how to take apart the the fridge to find they line or water tank (if it has a water tank)
The schematics for your unit is not very good, so I had to give you the generic answer. If it doesn't have a standard valve, because of the built in water filter, then the enclosure for the water filter is also the solenoid controled valve.
Completely understand and appreciate taking the time to answer. You lead me to look on the sears parts website and I found the water valve is part of the ice maker assembly. I will take off the cover and check it out. Thanks.....
SOURCE: Fabric softner is building up in dispenser
Same deal - I have to soak up all the residual water in the softener dispenser between washes. (The detergent and bleach compartments are fine).
SOURCE: Samsung RS21DCNS: Ice maker fills up but water dispenser does not dispense water
the fridge is making a noise , sounds like a fan catching and the water will not flow
the firdge is a Samsung RS21DCNS 19.6CF
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
SOURCE: Front ice/water dispenser stopped working.
I had the same problem. Turned out to be a microswitch under the lever used to activate it. The microswitch fell from the original position so it wasn't turning on anything. I tried gluing into position but the fumes from the crazy glue messed up the switch and I had to replace the whole rig.
The part is under the control display. You can pry it open from the left side.
