Question about Bushnell Neo Handheld GPS Receiver
I cannot register my Bushnell Neo+ with igolf.com, it is telling me that there is an invalid product ID that i am entering, however I am entering the ID number on the back of the device as per the instructions. Any ideas?
Posted by jcrcrane on
  • 1 more comment
  • jack_kalis97
    jack_kalis97 Jan 24, 2013
    i have the some problem
  • dwgcrow Jun 16, 2013
    I have the same problem too !!!
  • SF Holahan Jul 29, 2014
    I think they have an online chat and I had a glich resolved via that path.
James W Chappel
I had the same problem with my bushnell neo plus. I used the igolf.com website's support/contact to ask for help, included my unit's ID. Igolf responsed teh next morning by releasing my ID. I was able to setup my profile and sync my device without a problem. Try igolf's customer support, impressive.
Posted on Sep 12, 2012
SF Holahan
    New Friend:
  • 8 Answers
If you commit to Igolf access (free or subscription), be aware that it is mmarried to Java Script version 6. If you replace V6 with Java's newer V7, the application will not launch. You'll have to remove V7 and go searching for a V6, and Sun is saying that after Feb 2013, they will remove the V6 download option. Nasty. Igolf should alert their memberships and Bushnell should address this software issue.
Posted on Feb 26, 2013
2 Related Answers
Anonymous
SOURCE: my igolf neo won't work with Windows 7 if i try
I fixed this problem by going to Start>Control Panel and uninstalling the Java 64-bit program. It is incompatible with the Neo sync application. The other Java program on there is compatible. It worked immediately without even restarting. (I tried the above Best Solution, but on the newer computers, I get a message saying the Vista driver is only for Vista, not for Windows 7).
Posted on Apr 17, 2011
drifterK
Catalin Turcu
  • 4924 Answers
SOURCE: Loading Bushnell Neo to anew
I think that you should browse manually from that point and select the browser if this is what it asks for ..or ...insert the disk ..and connect the device ..and get from the browser to the manufacturer site..and see if they have a wizard you have to run for the procedure...I know for sure that the map loading requires some wizard ...
if your maps are not from Bushnell ...and are from Garmin for example ...get to the site from where the maps are ..
Or just look on the disk if there is such a wizard /program that you might need to run first ..
Posted on Feb 12, 2011
Bushnell neo+
The wording on this question is almost word for word of a message I sent iGolf customer support. If it's my message I don't know how it showed up here on fixya. Sent it also to bushnell support, both said in essence that a demo unit won't work, although i have seen factory demo's being sold on various websites. 1 tech. @ IGolf uploaded to me 2 files EMBEDD01.GLF and SYSREG.SMI which I loaded on th my neo+ after deleting both of the 2 files originally on the unit. But again everthing works, satallite signal strong, courses are loaded but no yardage is shown. It seems to be working when mapping a hole on the course (front, center, and back) but on resume play hole shows no yardage.I believe it's the firmware that is in the demo unit. my ? to iGolf and bushnell was if there was anyway to update the firmware but neither gave me an answer.
Jul 28, 2013 • GPS
2helpful
Can not sync devicebushnell neo+
If you have a PC (Windows) then you MUST use Java V6 as the software interface between your computer and the Igolf site. If you have already switched to Java version 7, it just won't work. Google: neo Java and you'll begin to see the problems. No support from either Bushnell or Igolf on this. I had removed Java (re: all the recent security issues being discussed and installed V7. The application would not launch. I had to remove V7 and go fishing for V6 on the internet and reinstall it. Then I wwas back to it working. There are a number of other issues people are having (two accounts on the same machine... neo and trying to register neo+), Registration expirations, etc. If you can reach the Igolf/Bushnell real technical support people, you will have a better time of getting what you need to work. GEEEEzzzz. Bad, Bushnell! The neo series is great but this iGolf married is playing havoc on your customers!
If you have a MAC, then you need to Google MAC, etc.
My computer uses Windows 7. When I first got my Neo I had a computer that used Windows XP. When I got Windows 7, I had to change my email address. I am not sure what Igolf records show, but my current...
the neo may not be compatible with win 7
get to properties for neo and click on the compatibility tab
click the box and highlight win 7 and apply
5helpful
2answers
My igolf neo won't work with Windows 7 if i try
1helpful
Recently received a Bushnell Neo for Christmas and having problems loading Bushnell Neo (provided) software to my computer. I have Windows Vista Home Premium and can't get past Quick Guide step 6,...
I've had the same problem today and found the following advice:
Solution:
1) Click on your Start Menu
2) Select Computer
3) Open Local Disk C.
4) Open Program Files
5) Open Bushnell
6) Open Neo Sync
7) Open Native
8) Delete IGolf.lck
9) Close out of everything, restart your PC, and attempt to launch the Sync Application again when your computer has started back up.
If the above fails to solve the problem, you need to install a new USB driver. Contact iGolf at 858-300-5513 858-300-5513 and they will email you the PL2303 Prolific Driver.
I downloaded the driver from
http://www.prolific.com.tw/eng/downloads.asp?ID=31
rather than send an email and now have it working on XP, Vista and windows 7 starter.
G.
5helpful
2answers
Downloaded the sync app to my pc but it won't install.
This seems to be a problem on PCs using Windows 7.
Solution:
2) Select Computer
5) Open Bushnell
6) Open Neo Sync
7) Open Native
8) Delete IGolf.lck
If the above fails to solve the problem, you need to install a new USB driver. Contact iGolf at 858-300-5513 and they will email you the PL2303 Prolific Driver.
1helpful
I have a backup folder for all my courses. I accidently deleted a course in "My Courses" section of the software. I copied a backup file into the igolf folder where all of my courses reside. It's in the...
This solution applies to the newest version of iGolf Neo Sync. If you don't have the newest version download it from the IGolf site. Open iGolf Neo Sync and all of the courses in your backup file should appear under "My Courses". If all of your courses don't show up, click on "Settings" under "MY DEVICE" . On the page that opens you will see the tentative location of your backup files (for example, C:\Golf\Backup). If the location isn't correct browse for the right location. Once you find it click OK. Now all of your courses should show up under "MY COURSES" on the iGolf Neo Sync page. You can then send any of the courses to your GPS.
Bushnell Neo Handheld GPS Receiver Logo
Top Bushnell GPS Experts
ADMIN Canada
ADMIN Canada
Tom Chichester
Are you a Bushnell GPS Expert? Answer questions, earn points and help others
