Check settings for mtu westell 7500
SOURCE: westell 6100 problems
we had the same issue. Here is how we fixed it. I had the xbox 360 plugged directly into the westell 6100 modem via ethernet cable. the mtu test failed everytime. I was extremely frustrated and called microsoft and verizon (dsl) about 10 times each and they kept giving me the wrong solution. (get a new modem, get a new server, pay us money and we'll figure it out etc...) Here is what a man at microsoft told me to do and finally it worked. Power cycle your equipment (unplug modem and xbox 360 for 30 sec.) then, plug in modem first and wait until all lights are back on. Then plug in xbox and run test. In my case mtu failed again. I was then instructed to go to my dashboard and restore xbox to factory default which I did and rerun the test. This time everything FINALLY passed. We were in business. I then decided to try connecting through my airport extreme router. I power cycled again starting with the airport then the modem then the xbox and ran the test and unbelievable as it sounds it all passed and my son is now sitting happily on the couch playing a game online with his xbox 360. This took away days of my life to get this simple thing done. I was given codes to change and change back on the computer, phone calls to everyone and the solution was so simple when you finally reach a knowledgeable person. Hope this will help save someone else the time I spent!
SOURCE: how can I change the minimun MTU value on my router?
I use tcp optimizer, it's by far the easiest way to change those settings.. it is available for free download here. Make sure you read the instructions on the download page.
http://www.speedguide.net/downloads.php
Regards
SOURCE: I got it thru Verizon (Westell Model num.
You are trying to open the NAT on the router for X-box.
For this you will need to reduce the MTU settings on the router to 1365.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.Router set up page is the page where you can change the settings of the router
Click Here to know more about router and network
SOURCE: I need to change mtu settings in order to get my x
check out the link below to find out how to solve your problem
http://support.xbox.com/support/en/us/nxe/xboxlive/troubleshooting/networkhelp_mtu.aspx
SOURCE: Where can I get a
Try here
http://onlinehelp.verizon.net/consumer/bin/pdf/VersaLink7500UserGuide.pdf
