Question about Bushnell Voyager 78-9945 Telescope
I have taken both caps off and set the findascope to an object 200m away. I have then used the eye piece with the highest number on it (H12.5mm) I can't see anything..Please help, I need simple instructions.
SOURCE: I need to find a user manual for a Bushnell Telescope Bushnell Voyager 78 78-9675 78-9675
Hi - You can download the manual from the link underlined in blue below:
78-9675
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Posted on Aug 09, 2008
SOURCE: the eye piece keeps falling
There are several different types of eyepiece holders:
Set-Screw-- this is a small screw on the side of the diagonal that holds in the eyepiece.
Compression ring-- again a small set screw but a brass compression ring tightens onto the eyepiece.
Plain Compression Diagonal-- the diagonal is a tight fit to the eyepiece- try binding it slightly in to get a tighter fit.
Posted on Dec 28, 2008
SOURCE: bushnell voyager AN-78-9565
Not worth repairing-- a new focuser for your telescope would cost as much or more than the telescope-- unless you can find a discarded telescope of the same model..... for parts.
SOURCE: I have a new bushnell voyager 78-9945.
Use the lowest magnification eyepiece until you learn how to focus-- it will be the one with the LARGEST number written on it.
Also go out when the moon is up and less than 3/4 full and practice on the moon.
Posted on May 16, 2009
SOURCE: Bushnell 560 Telescope eye piece
Try contacting Bushnell directly.
800-423-3537 Toll Free
Posted on Oct 01, 2009
Jan 01, 2016 | Bushnell Optics
Jun 30, 2013 | Bushnell Voyager 78-9945 114mm Refractor...
Sep 30, 2009 | Bushnell Voyager 78-9565 (120 x 60mm)...
Jul 15, 2009 | Bushnell Voyager 78-9565 (120 x 60mm)...
Jun 09, 2009 | Bushnell Voyager 78-9945 Telescope
Dec 26, 2008 | Bushnell Deep Space 78-9512 (120 x 60mm)...
Dec 17, 2008 | Bushnell Voyager 78-9565 (120 x 60mm)...
Apr 19, 2008 | Bushnell Voyager 78-9945 Telescope
Jan 12, 2008 | Bushnell Voyager 78-9565 (120 x 60mm)...
May 15, 2007 | Bushnell Deep Space 18-1560 (150 x 53mm)...
164 people viewed this question
