Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
Anonymous Posted on Mar 01, 2018
Whirlpool ED22TEXHW02 The upper half of the freezer and the refrigerator won't cool. The bottom half seems to be cooling fine. I have checked the compressor and it seems to be working as well. I am thinking that maybe a baffle might not be functioning properly, but I am not sire how to verify this.
Gary Dumers
Level 2:
Habit-Forming:
New Friend:
  • Expert 131 Answers
  • Posted on Mar 03, 2018
Gary Dumers
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
131
Questions
Helped
48363
Points
371
Be sure to check the door seal.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
3 Related Answers
Anonymous
  • 523 Answers
  • Posted on Dec 18, 2009
SOURCE: Whirlpool EB22 - Are there two compressors on
is the evap fan running? is there frost in the freezer?
Anonymous
  • 6784 Answers
  • Posted on Dec 21, 2009
SOURCE: Whirlpool Refrigerator not working
Hi. Due to the fact that the fans are not operational, this will confirm that the Main PCB has failed. This is the main power control board. It must be replaced, asap. The general location of this affected board will be just behind an access panel, near the compressor unit, or on the backside, mounted in the middle section of the unit.
Once the Main PCB board is replaced, the unit will return to its normal operating status.
woodchuck789
Charles T Nevin
  • 4070 Answers
  • Posted on Nov 27, 2010
SOURCE: My one year old whirlpool
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it'll be the control.
The fridge (kenmore) doesn't seem to be cooling but the freezer (on the bottom) seems to be working fine. Help! :((( Single mom
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
1helpful
My whirlpool refrigerator is not cooling but my bottom freezer is fine
heatman101
Ed2vhex side by side won't cool on refrig side. Freezer side is cold. What is the problem. It is under warranty.
heatman101
The top part is the freezer and it seems to be working fine but the bottom refrigerator part is not getting cold enough
heatman101
Freezer and fridge not cooling (halfway)
SxS Amana upper half of feezer and Refrigerator not working
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
