Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
check or replace the big white gear......that goes with the solenoid,the inside of that gear should have a little spring...if its mising get another gear.....good luck
also check the shaft with the
Make sure that the printer track is free of any torn paper. Make sure that the tractor feeds themselves are free from debris. Turn it off during this check.
I have a HP Photosmart A626. The paper won't feed. It seems like something is blocking it and sometimes takes me 5 minutes to get it in where at that point the paper is ruined.
paper feed rollers wont feed paper through and also paper tray is empty prompt comes up when there is paper in the tray tried small amounts of paper and still says tray is empty
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up. 2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.) 3. Insert the paper roll from the left side of the paper holder and make sure the paper roll is set in the proper direction (with the paper feeding from the bottom). 4. Insert the leading edge of the paper into the opening directly behind the print mechanism. 5. Press the paper feed key and feed the paper under the edge of the paper cutter.
you wont have to feed the paper just try to print and it'll feed the paper automatically. but if there is a problem in mechanism that will be your problem, you'll have to bring it or just call a service tech.
