Linksys WRT120N Wireless Router Logo
Question about Linksys WRT120N Wireless Router
Reset password to the router and get a new one
Posted by mario_jim990 on
Prashant M
  • Linksys Master
  • 2,278 Answers
Are you trying to reset the router password or wireless network password?
Wireless network password is different than router access password.
To change the wireless password, you will need to access the router page and change the settings.
See how to find wireless network password
To change the router access password, you can log in to router page and go to administration tab. There you will find the place to change the router password.
Posted on Jan 09, 2012
2answers
How do I recover from forgotten admin password?
Some routers have passwords printed on the bottom. Most routers use "admin" as username, and then either default password or unique password. In any case, read the user manual, you should find it there. Download Free Manuals
We lost our password. Wanting to reset the password
A forgotten or lost router password cannot be recovered. It can only be reset by hard resetting the router. ....read more to reset password
Trying to change temporary password to new password
In order to setup security on your router and create new password you will need to reset your router to default settings. to do that press and hold the reset button for 15 seconds or until router resets then depending on the router you have you will need to access the router configuration.
In the address bar for Belkin Router type 192.168.2.1
Linksys: 192.168.1.1
3helpful
I forget the my password
How to Reset a Password on a D-Link Router
Use a pen or a paper clip to push the "Reset" button on the back of the router. Keep the button held down for approximately five seconds.
Open a web browser on a machine that is connected to the router. Type "192.168.0.1" into the navigation text box.
Type "admin" and leave the password blank. This is the default information for D-Link routers. When you hold the reset button down, it resets the admin password to blank.
Click the "Tools" tab at the top of the D-Link admin console. In this screen, you can reset the admin password to a new one.
Enter the new password in the router's console section labeled "Administrator Settings." Enter it a second time in the "Confirm Password" text box and click the "Apply" button. The router's password has now been reset.
If this answer helpful please vote me.
Good luck.
Thanks for using FixYa
2answers
How to change the password on a Buffalo wireless router?
Unfortunately there is no way of recovering your router password, However you have the option of resetting you wireless router keep in mind this will reset your router to default settings so you will want to secure your router once reset. There is a reset button located on the back on the router simply press and hold reset button for 15 seconds or until router resets, You may need to use a paper clip to access reset button.
Tried to reset password..seemed easy enough,done.. reset router name easy, reset password easy. reset ssid easy..in fact my password was the same for everything to make things easy. Now i go downstairs...
Router paswords are chase and space senitive, Reset the router and choose a different password that not been used. then repower the router, and connect using the new password.
1helpful
2answers
I FORGOT MY PASWORD FOR THE WIRELESS ACESS AND I NEED TO USE THE INTERNET ON MY NEW LAPTOP HOW CAN I MY PASSWORD OR RESET THE PASSWORD
connect your router to computer with ethernet cable.
Then you can access it with following link.
for belkin routers http://192.168.15.1
for other routers
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.Click on wireless and If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
If you are not able to access your router with above link then RESEt it you can find RESET button in back panel of router press it for 10 seconds.Then all settings are defaults.
Let me know if you need further assistance.
112helpful
How to reset my new password (D-link DIR-300)
when we forgot all.so from which purpose we can reset the router password i want the solution urgently.
31helpful
6answers
Forgot my belkin router password is there a way to reset it?
here you go, from Belkin's website
Reset the router to factory default Resolution With the router powered on, use a small thin object to press and hold the reset button for exactly seven seconds. The router lights will flash and this will restore the router to factory default. Connect your computer to one of the routers lan ports with an etherent cable. Open your web browser and navigate to 192.168.2.1. This should show the router status page with the default settings. SummaryThis article describes how to reset the router to factory default More InfoThis article assumes you cannot access the routers web interface.
Top Linksys Computers & Internet Experts
Donivan Wise
Mike
Mehandi Husain ...
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
