Philips hf3461 - radio works but sounds don't
Hi i recently was given the above product as a gift, I've tried setting it up and the light and radio work fine but the other 'sounds' eg birdsong, running water, frogs, do not seem to work at all. Has anyone else had this problem?
  • 17,130 Answers
Please reset the player and see if this will start back. Also connect to PC and scan the PC for error files, delete and format the memory and load the safe files.
Posted on Jan 19, 2012
6ya staff
SOURCE:
I've just been given a second hand Daewoo fuzzy logic DWF 4094R. I've been told it works fine, but it has a hose missing. This didn't worry me because I like to do cold water washes. But I
I don\'t under stand what help you need.
If the cat urine smell is outside of the appliance then wash it down with Clorox.
If there is a filter on the output of this machine then service that before doing the next step.
If the odor is inside the machine then run Clorox for a couple of long hot cycles AND then run white vinegar in it. The Clorox will sanitize and the white vinegar will loosen and remove minerals that hold odor.
Add a quarter cup of white vinegar to each load until the odor is gone or your clothes will stink.
My thought is that there is a reason they gave you this "working" machine. If you have further issues then let us know.
Good luck,
Mike
Feb 05, 2013 | Washing Machines
Kicker dx 500.1 keeps ruining my subs
if your sub isnt blown, i'd follow your own idea and look for a bad wiring connections, also what kind of head unit do u have? check the settings on ur head unit to see if there is a seperate setting for your amp/subs if it does have one, make sure it is set properly
if it does not have a setting like above, check the rca cable from the radio to tthe amp, and make sure that the rca cable is plugged in to " input instead of the output
Jan 15, 2013 | Kicker 2010/10 Dx500.1 Car Audio Monoblock...
Turn signals in my 98 Toyota Camry don't blink. And the the front passenger window doesn't work. Niether does the car lamp inside the car.
If just one window doesn't work, that is a separate issue, and probably a bad motor for that window. The inner door panel would have to be removed to investigate if it is the motor or a wire not connected.
For the radio and lights, all I could say is check the fuses.
For the blinkers try a new flasher. I've never heard this before, you must be pretty adept at it by now. Wiggling it to make it work means either the connection is poor or the flasher has a foot ******- Replace it!
Jun 17, 2012 | 1998 Toyota Camry
Hello, I have a 1998 camaro v6 r/s and I'm having trouble getting the head unit to stay on because it always cuts out and comes back on. also the speakers are semi new and shouldnt have blown but there...
Ok, if this radio was "hardwired" into you vehicle, this can get real tricky. If that's the case, I would recommend you take it to a professional. You run the risk of frying your electrical system. However, if the radio was installed using a harness, this is easier. I would remove the radio and check the connections of the radio to the harness. Soldering them and heat shrinking is best, **** connectors second best, twist and tape...please don't. Try to check the wiring. Hope this helps
Sep 03, 2011 | Car Audio & Video
Lost the instructions on how to alter the light -shows pics dark?
Hello nfwiseman,
I've given you a "Link to the Website,"
where you can get a 'copy' of the "User Guide."
It will have the instructions that you need to "Set-up the Lighting."
Now, there is only one 'problem'!
The Philips 10FF2M4/00 ("Product that you have is not 'listed' in the USA").
So, if your are in a different "Country?
You will have to provide that information, in the [Drop-down Box];
of the "Country," to get the "Manual."
I'm trying to 'save' you time by giving the "Website;" instead of,
requesting more information.
"Just 'click' on the URL below, to go to the "Website."
"I hope this information helps."
If you need help with anything else?
"Write a 'comment'; I'll be here to assist you!
"Best Regards"
Click below for "Manual" ->
http://www.support.philips.com/support/search/search.jsp;jsessionid=6B770B001467F8C0C0C2B5856FCE2C96.app106-drp2?userCountry=us&searchValue=Philips+10FF2M4/00+&fetchWhatData=WorldCategoryData&userLanguage=en#
Aug 15, 2011 | Philips 10FF2M4/00 10.2" Digital Photo...
I got a brand new cd/clock radio (above number), and I can't get the cd player to work. Makes a sound, but won't play disc.
Hi! since you've just purchased your unit, it's under WARRANTY period. Please don't touch or try opening the unit. Return the unit where you purchased and tell them exactly your problem. You don't have to pay anything. Bring with you the warranty card and Official Receipt. Thank you.
Jun 14, 2011 | Vacuums
Hi! I have a Jensen XA2150 Amplifier, from the speaker output I have connected a Subwoofer Sony 10 inch 1100W. Tha'ts gave me a nice bass sound, but now it's death! The amplifier have a 25A fuse,...
Have you checked the fuses inside the amp?Unscrew the cover and with the amp sitting on its back,remove the cover.You have 2-4 fuses,old round type,in there.
May 21, 2011 | Jensen XA2150 Car Audio Amplifier
114 people viewed this question
Ekse
 Grubhead
Grubhead
