Need operating instructions
SOURCE: operating instructions for timex t311t radio/alarm clock
Regarding how to set the time on a T311T Clock:
1. Push down the Time button and hold until number start flashing.
Push the right arrow until the time advances to the time desired.
2 To set the date, push the date button and hold until date starts flashing. Push the right arrow until the date advances to desired date
SOURCE: need operating instructions for RCA clock radio Mod. 5430
The instruction manual will not help you, because it doesn't address this problem head on. You're having this problem because the time changed, and the clock has an automatic setting. As long as the batteries are in the clock and it's plugged up, it automatically computes the time. I just discovered the solution. Unplug the clock, take out the batteries and WAIT about an hour. Plug it back up, and the time will flash, allowing you to change the time. You do this with the button on the top back which says wake up 1 and wake up 2. Push that button all the way to the right to the setting that looks like a little clock, then press the forward button on the top of the clock to set the correct time. Then put your batteries in and you're good to go! (til the time changes again:) Good luck!
You can acces a PDF file of the manual at the following site: http://timexaudio.com/media/uploads/product/files/T311IB57574_35.pdf
SOURCE: Cannot turn off the alarm on my RCA clock radio rp5430
Look at the display. Look for a number 1 or a number 2 to determine which alarm is on. If you see a number 1, push the 1 button on the top right side of the alarm clock until the number light goes off (1 or 2 times, depending on whether it is set to beep or radio alarm). When the number is not lit up, the alarm is off.
Press and hold Mode for a couple of seconds. The musical note or the alarm will flash for a few seconds and then go off.
