You mean the main relay cornect get burned up? my main relay not click when I turn the key on II then I change main relay but still the same, I check all wire in main relay cornect they all have power, I think I don't have enough ground in it, then I try to cornect derect outside ground to it then I see the check engine light on then it stay on but not off after 2 second and i hear the relay click only one but the fuel pump still not pump then I try to start but it still won't, still have no spark, then i try to read code from the ECU, but don't see any light on from the ECU. or ECM even i try change the ECU but still don't see anything change.
Main relay contacts get burned up...... common on the hondas its under the drivers side dash
http://howtobyme.blogspot.com/2011/12/car-crankshas-spark-but-will-not-start.html
The spark plug firing order for car?http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
----------How to gap spark plug ?http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html-----------Spark plug Replacing for?http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
-----------How to identify number one spark plug on the distributor cap?http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
---------How does the spark plug wire go on the distributor cap?http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
---------Spark plug Firing Order Diagram?http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
-----------This will help.Thanks.
90 camaro rs 5.0 engine new fuel pump new relay turn key on no pump noise or will not ru
check engine light doesnt even light at begining cycle of key
I have a bmw 318is 1,9l 1998 model no spark have aligned the ews key and dmsand the car just swing does not pump fuel and fuel pump is new but there is no fuel coming checked voltage on the connectors its there but still nothing is happening engine was recently done what could be the problem pliz help
