Question about Samsung RB2155SH Bottom Freezer Refrigerator
How do I remove the inside back panel on a Samsung Model # RB2055SL?
I'm trying to remove the back inside panel of a Samsung Model # RB2055SL. I've removed 6 screws (4 along the bottom and 2 about midway up). I've also removed the small cover to expose the temperature sensor. I can snap the sides out but it appears to be stuck in near the middle.
Posted by Doug Penhall on
5 Related Answers
douglas smith
  • 1462 Answers
SOURCE: SAMSUNG RS21DCNS
speaking from memory: remove the middle translucent section held by one screw at top and clips. you will then see the additional screws you need to undo
Posted on May 07, 2007
shaun greyvensteyn
  • 159 Answers
SOURCE: Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
Posted on May 22, 2009
Anonymous
SOURCE: Door Removal
If you don't have the manual, go to Samsung's website and download the manual. It explains how to remove and adjust the doors and bottom drawer.
Posted on Jul 25, 2009
Anonymous
  • 59 Answers
SOURCE: Samsung RL36SBMS Bottom Freezer problem
LOW HUMMING NOISE COULD BE THE COMPRESSOR CHECK CAPACITOR
Posted on Aug 19, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Our refridgerator is not getting cold! it is
Please double check your model number because that number is not listed. I am pretty sure it has a dual evaporator one for freezer and other for the fresh food compartment. Check behind the cover of the fan inside the fresh food compartment to see if the coils are icing over. Send me the correct model number will help me decide if it is something different. I will even send you a Service manual with the correctmodel number, Thanks, Sea Breeze
Posted on Feb 12, 2010
Samsung rb2055sl running warm 55 degrees in refrigerator and 70 degrees in freezer fan is working no ice, way to warm
Is there a clicking noise? Feel the compressor to see if too hot to keep your hand on top. Look ate the frost pattern in rear of the freezer compartment and tell me the results. Several things could be causing the compressor to get hot and not run. Freon leak is one thing that could happen and defective start relay, overload and run capacitor is another. You could also have a defective cooling fan under fridge or inside the freezer compartment
APPLIANCE 911
Sep 18, 2016 | Samsung Refrigerators
Why freezer part is not working on my samsung rb2055sl
The most common part to replace is the timer motor. It's usually located on the back bottom of fridge, It's a little thingy about 1 1/2 " in diameter. One screw will usually get it loose where you can take a look at it better to see if it's turning. It has a small window where you can see a little wheel turning.
Sep 05, 2014 | Samsung RF265AA Bottom Freezer French Door...
Don't know where to hook up little black wire in the back
If your amp has an earthing terminal on the rear panel connect it there. If not remove a turntable rca plug from your amp and sit the wire on the inside of the plug then connect back to amp. Cheers John. Styluscity
Sep 10, 2012 | Technics Audio Players & Recorders
How can I best access the pump on my Samsung front load washer? I don't know how to remove the front panel
Some samsung washers have the water pump located in the back of the machine. If your model does not have a small door located in the bottom of front than remove back service panel to access the water pump.
Jun 21, 2017 | Samsung WF328AAW Front Load Washer
I need the part number of the door switch of my Samsung Regrig. Model# RB2055SL
Hello there:
here is the number that you are refering to
Door Switch DA34-00006C ok?
best regards michael
Oct 08, 2009 | Samsung RB2155SH Bottom Freezer...
Samsung model LNT5271f excessive relay cycling before full power
Howdy,
Yes, it is very easy to repair. Solder iron wattage should be at least 300 w.
The PSB is the center Board (towards left) after you remove the back off the TV. Remove the shield that covers the Boards and remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Good Luck, big IRISH.
Sep 28, 2009 | Samsung LN-T5271F 52 in. LCD Television
Samsung RB2055Sl Top refrigerator couling coil freezing up every 2 or 3 weeks
The problem is freeze up. Bad door gasket or too much window shopping are the biggest issues. Could be low gas. Either take off the back freezer panel and defrost or unplug for 2 days to defrost fully. Oh, and clean the condenser coil. Then, let's see what the unit does.
Nov 27, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RB2155SH Bottom Freezer Refrigerator Logo
545 people viewed this question
Top Samsung Refrigerators Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
