Question about E-Machines T Computers & Internet
How to manually recover emachine t1400 - T E-Machines Computers & Internet
Posted by andrew_melch on
Keith Fox
  • 641 Answers
When the computer first boots up, it will go through the POST. Which is power-on-self-test. Right after this press F1 to get into the BIOS. BIOS is Basic-Input-Output-System. Inside the BIOS you can configure your boot options. You can move the priority of the CD ROM or USB to the top, above the hard drive. (I'm guessing the Operating System is inoperable.) You can now save and exit. insert a windows disc, to repair or format the hard drive and reinstall the operating system. I recommend though trying Ubuntu. visit ubuntu.com for install instructions.
Posted on Jan 09, 2012
How to install photo cell on timer
You posted under T1471BR timer.
This is a 4PST timer
Do not install photo eye on input voltage from breaker box, because that will stop timer clock from operating except nighttime, and then clock time will be off.
The timer clock terminals are A and B, so Connect white neutral to terminal A and black Hot wire to terminal B.
The terminal switch terminals are dry and receive no power when input terminal A and B have power.
Copy following link for illustration showing typical timer wiring.
http://waterheatertimer.org/images/T1471BR-wiring-500.jpg
Using illustration above: If You want to add photo eye, Remove black wire from terminal 5 to light bulb. Then Connect photo eye black wire to terminal 5, connect photo eye white wire to white wire at light bulb, and connect photo eye red wire to black wire at light bulb.
Copy following link for Intermatic T1400 series product manuals, 3-phase wiring, etc
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#T1400
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 14, 2012 | Intermatic T1471BR Timer 4PST 40A 125V...
Tip
How to Recover eMachines Notebook Windows Password
eMachines, as a brand-name laptop, is attractive to many netbooks users. We also call it as Acer eMachines for its developing history. We often receive letters from eMachine notebooks users on Acer eMachines password reset for forgotten eMachine administrator password. How to remove eMachines password or change eMachine password if I forgot Windows 7, XP, Vista password? Now, begin discuss the ways to unlock eMachine password.
1. Reset eMachines administrator password with other admin account
This means that we still can login our computer by accounts with administrative rights or privileges. Please never forget the default administrator, it may help much!
eMachines XP password reset from Safe Mode
A. Switch on eMachine Windows XP laptop and keep pressing F8.
B. Opt for "Safe Mode" and press "Enter" key at the Advanced Boot Option windows.
C. At login screen, choose the Administrator account and keep "Password" column blank (or input the changed password if the default Administrator account password has been changed before).
D. Start - Control Panel - User Accounts - select the account needed to change password - Change the password.
E. Input a new password, confirm the password again and then complete
Acer eMachine password removal on XP.
eMachines password recovery on Windows 7
We can recover forgotten password with built-in admin account:
A. Power on Acer eMachine computer and press the key: F8.
B. At the Windows - Advanced Boot Options, select "Safe Mode with Command Prompt" and press Enter to confirm. Then PC starts Windows.
C. Choose the Administrator account shown on the account screen, and then login windows - Administrator: cmd.exe. Input command: net user Lily abcd and Enter to confirm (Lily is the account needed to break password; abcd is the new password for the account).
D. After command finished, we can restart eMachine Win 7 laptop and login with account - Lily, password - abcd.
2. Break eMachines password with only guest account
We know that the guest account can not do more operations on a security PC. So, we have to refer to other way to retrieve the admin account for further operations.
Bypass eMachines password with recovery disks created before lost eMachine password
When input an incorrect password at the login screen, click "Reset Windows Password" and insert the eMachine password reset disk. The Password Reset Wizard will lead us create a new password to remove forgotten eMachines Windows 7 password.
Retrieve eMachine Windows password by DIY a password reset disk after forgotten
It is considered as the most instantly and easiest way to recover lost eMachine password. A .iso file, bootable CD/DVD/USB disk and accessible PC will solve problem within minutes without special techniques for a green hand on PC.
We can get the .iso file from many Windows password recovery programs. Just take one of the most popular tool - Ainorsoft Windows Password Recovery as example.
A. Download the suitable Ainorsoft Windows Password Recovery program and burn its .iso file into a blank CD/DVD or USB Flash Drive on an accessible computer;
B. Boot the burned CD/DVD or USB Flash Drive from the PC password locked;
C. Reset the new eMachines password.
Ainorsoft Windows Password Recovery tool concludes Basic, Enhance and Corporation versions. The Basic is opted for Windows 7, XP, Vista, 2008, 2003,etc. CD/DVD disk suits for it! The Enhance version can be used with USB disk for the former OS. While, the Ainorsoft Windows Password Recovery Corporation is designed to Windows 7/Vista/XP/2000/NT/Server 2008/2003/2000 with bootable CD/DVD or USB Flash Drive.
Main methods on eMachine password reset are shared as above. Recover forgotten eMachine laptop password from Safe Mode or unlock eMachines password with password reset disk. Hope the any one help our eMachines computer users!
Article source: http://windowspasswordrecovery.net/article/emachines-password-reset.html
on Jul 08, 2011 | E-Machines eMachines Desktop PC
Instalation photo cell on timer
How do i reset my emachine t5048 to factory setting without the windows boot disc?
Some computers will have a recovery partition you can recover from it will prompt you as the computer is booting. Emachines are very low end computers and don't typically have a recovery partition. If you didn't create the recovery disc you will need to order it from Gateway's website as they own emachine.You can order recovery media from https://secure.tx.acer.com/RCDB/Main.aspx?brand=emachines
Oct 17, 2011 | eMachines T5048 PC Desktop
My computer won't boot up and the orange light just stays on. The moniter is working, the fans in the power supply is working. I was fine yestyerday. I put in hibernate and tried to cut back on today...
Remove the RAM and install it again and restart.....it will work if still not work then change remove RAM again and start your machine..it will give beep sound...if it will not give beep sound then understand your machine's mother board is faulty......
Sep 09, 2011 | E-Machines eMachines Desktop PC
How to recover audio from an eMachines T6534
To recover audio files lost from digital recorders, you can try this program called Digital Photo Recovery (also recover AUDIO and video files). If you are running Mac OS X, turn to Photo Recovery for Mac (also recover videos and audio files on OS X).
May 18, 2010 | eMachines T6534 PC Desktop
Im trying 2 get my acer T1400 laptop 2 go on the internet do u have a manual 4 my laptop
Normally you do not need the manual to go to the internet, just insert the cable(internet) to your laptop and then it should have the connection.
If not try to call your internet provider, some times you need to insert a code provided from them
acers homepage is here if you want to find the manual :
http://www.acer.com/worldwide/selection.html
Let mee know
Aug 24, 2009 | Computers & Internet
I would like to make a recover cd for my emachine 770.
Hi M_Borland,
You could consider making Ghost CD's but that wont get you back to a factory setting, So if your computer is having issues Ghosting the system wouldn't be the best option. If you are interested in Ghost check out Norton's website. You could contact emachine and see about getting replacement CD's. Hope this answers your question.
Thanks,
Armymason
Feb 24, 2009 | E-Machines eMachines Desktop PC
Computers & Internet Logo
78 people viewed this question
Top E-Machines Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
