The "rm ed007" remote that you mentioned is most likely a universal remote control, which can be programmed to control multiple devices, including your Sony DVD player and Sony Bravia TV.
To program the remote to control your Sony DVD player, you can follow these steps:
Turn on your Sony DVD player.
Locate the code for your Sony DVD player in the code list provided with the universal remote.
Press and hold the "Code Search" or "Setup" button on the universal remote until the indicator light turns on.
Enter the code for your Sony DVD player using the number buttons on the remote.
Test the buttons on the remote to make sure that they are controlling the Sony DVD player as expected.
To program the remote to control your Sony Bravia TV, you can follow these steps:
Turn on your Sony Bravia TV.
Locate the code for your Sony Bravia TV in the code list provided with the universal remote.
Enter the code for your Sony Bravia TV using the number buttons on the remote.
Test the buttons on the remote to make sure that they are controlling the Sony Bravia TV as expected.
PhilipsHere you can discuss all topics related to using Smart TV and Smart TV apps. Also find topics on IP-EPG, HbbTV, MHP, and Google Play store apps on Philips TVs Powered.... First of all JorisM, you're not the only one with this kind of Problem.Missing: 42pfl9703
forum.team-mediaportal.com > ... > Electronic Program Guide > WebEPG
Feb 8, 2010 - TV: Philips 42pfl9703 ... I found that data is loaded, but randomlystopped. ... EPG grabbing is busy, but still the system shuts down to early.
"If your recorder is stuck with UPDATE in the display you will need to hold the Power button for more than five seconds to perform a "soft" reset. It will switch off for a few seconds, then quickly and before it powers itself back on again , TAP THE POWER BUTTON 2 OR 3 TIMES , and it should say WELCOME and will then go to a black screen with no freeview channels
if you use easy setup and select location FRANCE or BELGIUM it wont lock up on epg update and will allow you to operate the machine
but epg wont work
this is a temporary fix until Sony provides a fix for epg problem.
If you whsh to get all functions operated with your TV, you must have its original remote control, and it is no doubt. No universal remote control will operate with all functions, that are supposed to be, especially to Sony Brands. You can buy the original remote control from the authorized service center for Sony, or from any authorized dealer for Sony. Then why do you go for an experiment
You haven't specified which type equipment you are experiencing the problem. With our DISH Network receivers, if the EPG does not display you can do 1 of 2 things. First, unplug the receiver from the electrical outlet for 10 seconds and plug back in. This causes the receiver to reboot and re-acquire satellite signal. Then it will download the EPG.
If you still don't have the EPG, you can then run a check switch test. Press the Menu button on the remote. Main Menu will display on the TV screen. Press 6 (System Setup), 1 (Installation), and 1 (Point Dish) on the number pad. Highlight the Check Switch button on the right of the screen and press select. On the Installation Summary screen, highlight the Test button on the bottom left. Press select. The receiver will perform a switch installation check. After the test is completed, exit out of all screens till you are back to the TV screen. The receiver will acquire satellite signal and download the EPG. I hope this helps.
Sony BRAVIA KDL-52W4100 52 in. HDTV LCD TV We need our Sony 52W4100 Bravia screen replaced. What is the cost? Part # 1-802-791-12, cost approx $2,251.54 + core Parts reference: Andrews electronics, 800 289 0300.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information http://www.freeview.co.uk/_retuneinfo/ If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box. For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/ For specific model information visit http://tvretune.co.uk/productmanuals
Press the [i+] button on the remote control to display the DIGITAL INFO menu.
Press the BLUE button to display the MAIN MENU.
Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
Press the RED button to start the auto tuning process for all available digital channels.
Wait for the process to complete.
If you wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time. You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information http://www.freeview.co.uk/_retuneinfo/
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information http://www.freeview.co.uk/_retuneinfo/ If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box. For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/ For specific model information visit http://tvretune.co.uk/productmanuals/
