How to restore a proline lvd1985wd lcd tv to factory settings
Seemed to have wiped out the digital channels after scanning for further channels - how can I either get them back or restore factory settings and do a first time instalation again?
The steps to reset a Digital Skyworth TV to factory settings may vary slightly depending on the model, but generally, the process involves the following:
Press the "Menu" button on your remote control.
Navigate to the "Settings" or "System" menu using the arrow keys.
Look for an option that says "Factory Reset" or "Restore Default Settings" and select it.
You may be prompted to enter a password. If you have not set a password before, try entering "0000" or "1234".
Confirm that you want to reset the TV by selecting "Yes" or "Confirm".
Wait for the TV to restart and go through the initial setup process, which may include scanning for channels and setting the language and time zone.
If you are having trouble finding the reset option, you can consult your TV's user manual or contact Digital Skyworth customer support for further assistance.
If your Viore TV is unable to scan digital channels after a power outage, there are a few things you can try to fix the issue:
Check the TV's antenna connection: Make sure that the antenna is securely connected to the TV and that there is no damage to the cable.
Rescan for channels: Go to the TV's menu and select "Auto Tuning" or "Channel Scan" to rescan for channels. Make sure to select the option for digital channels only.
Check for software updates: Make sure that your TV has the latest software updates. Go to the TV's menu and check for any available updates.
Perform a factory reset: A factory reset will restore your TV to its original settings. This can sometimes fix issues with channel scanning. Consult the manufacturer's manual for instruction.
Check your TV's location: Make sure that your TV is in a location where it can receive a good signal. Try moving the TV or the antenna to a different location.
If none of these steps work, it's possible that the TV's tuner may be malfunctioning and may need to be repaired or replaced. Contact the manufacturer's customer service or a professional technician for further assistance.
Regenerate response
How to put av on tedelex 72 cm TV model 9628MK11 72 manually
To manually switch the input source on a Tedelex 72 cm TV model 9628MK11 72 to AV, you can follow these steps:
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
only digital signal is available now analog has been switched off no longer transmitting. You could try returning in all of your channels from the main menu the tv can do this automatically but you need to select the procedure . retune the digital channels only 1. click on the home button 2. scroll sideways till you reach settings 3. in settings scroll down or up and click on digital set-up (centre button of your scroll control) 4.then scroll down to, and click on digital auto tuning (centre button of your scroll control) this will activate automatic channel tuning the tv will do the rest and will wipe out old settings and retune in all channels
If you have no recordings and it's playing up, I'd do a complete reset as follows;
Restore Factory Defaults
This will restore all the factory settings and erase the contents of the box.
Menu>Set-up>Help>Green>Red
Format HDD
This will re-partition and re-format the hard drive.
Menu>Set-up>Help>Green>Blue
This will wipe everything you have recorded. It will also dump your 14 day Electronic Program Guide which will take upto a day to reload. Leave the unit on standby.
You might want to take this opporunity to do a channel scan as well.
