Question about Sony Cyber-Shot DSC-W1 Digital Camera
Broken battery door latches? Try a simple practical solution.
Insert batteries. Close battery compartment door. Secure door with small plate held by 1/4" NC round head screw in the tripod mount. With a bit more effort one could mount a detachable handle at that location as well. Such a handle provides a more stable camera which is easier to use and is less likely to be dropped.
Posted by dalesfine on
1 Related Answer
Anonymous
SOURCE: Sony Cyber-Shot Battery Compartment Door Broken
I'm having the same problem with my DSC-W1 camera. I dropped my camera and the battery door latches broke.
I found a replacement door on Ebay for $9.95
I followed the instructions in the description and easily removed the broken door from my camera. Now i'm just waiting on the new door to arrive so I could slide the new door in.
I hope this was helpful.
Here's the seller I bought the door from. Hopefully the seller has more doors. =) :
http://cgi.ebay.com/Sony-DSC-W1-battery-door-silver-battery-cover-lid_W0QQitemZ110250995036QQihZ001QQcategoryZ107892QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
In addtion, I found the last two posts on this forum very helpful:
http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscw1_question.html?qid=2382
Good Luck! =)
Posted on May 10, 2008
The door that keeps the batteries and memory card will not stay closed. Can it be fixed?
Mine is broken also. There are 2 tabs in the cover and 2 raised slots on the camera body. When you open the battery compartment, you are supposed to slide the lid forward releasing the tabs from the slots, before the cover pops open. If you don't do this, you ~will~ break the tabs (or the raised slots). Well someone who didn't know this got a hold of my camera tried to force the compartment door open, breaking the raised slots that are part of the camera body.
Take a close look at yours and figure out how this latch is supposed to work and then see which part is broken. If it's the tabs on the door you can buy a replacement door online (do a search) and have someone good with electronics install it. (requires soldering). If (like me) it's the slots on the camera body that are broken, then it's not repairable. The original parts are too small and flimsy to be repaired (designed to fail). My best idea is to find some other way to latch the door closed. I've tried a velcro strap but it doesn't hold the lid tight enough and I've looked in hardware and craft stores for some kind of latch that might work, if I could atach it to the outside of the door somehow, but haven't found anything suitable (it would have to be small but sturdy and attach to the thin plastic of the door)
I'm thinking of taking it to a jeweler because they work with very small parts and might have something that could be screwed into the plastic door and camera body.
If you know of a better fix, please let me know.
Jun 15, 2010 | Canon PowerShot A720 IS Digital Camera
Battery life does not last.
The rechargeable battery has come to the end of its life. You'll need to replace the battery and let the new battery go through a complete charge cycle before using.
Jan 26, 2010 | Canon PowerShot A560 Digital Camera
Battery door latch broken
Unfortunately HP will not sell you a camera battery door. If you can find another camera that is broken with a good battery door you may have a chance.
To repair/transfer the new battery door, you will have to use a small jewerly store screw driver that you can buy at the dollar store and use it to push the door hinge bar to one side of the camera.
Then, pull the door hinge out but be careful not to lose the tiny spring that is installed in between the hinges. ( Make sure that you know and understand how to put it back the same way.) You can then pull the battery door from the camera.
Do the same thing to good camera. Practice on the broken camera first. The second time it should go easier for you. When you install the new battery door, push the hinge bar in all the way to one side of the camera. Hold the door to give you the proper alignment and then use the small screw driver to pry the hindge bar from the one side to make sure that it is equally in each of the black hinge connectors.
This worked for me. I was fortunate enough to find someone who had a broken HP MZ67 digital camera that had a "good" battery door. It took me about 30 minutes to complete the job. I hope this will help you. You can email me if you need more advice. I am a computer tech.
Steve ([email protected]).
Nov 15, 2009 | HP Photosmart MZ67 Digital Camera
How do i replace internal battery on the minolta maxxum 7000? i replaced the AAA batteries, but it still just flashes ''film'' in window.I have no manual and dont know how to get the film out.HELP!
Unscrew battery compartment on the right grip, and remove the battery holder (AAA's in most Maxxum 7000's) In the compartment you should see a silver colored metal plate, held on by 6 small phillips screws. Unscrew these, and carefully lift the plate, and move it aside (there's a tiny wire soldered inside the plate, so don't break it off).
Inside there should be a CR2016 lithium button battery. Replace it, and reassemble in reverse order.
NOTE: This probably won't fix any issues regarding the removal of the film, as the 2016 is just a memory backup battery for when the main batteries are removed.
to remove the film, install fresh main batteries, turn on the camera via the "Lock" switch and rewind the film. on the back of the camera, just behind the LCD screen, above the film door, you will see a grey button marked "R". Push and hold it, while sliding the gray slide switch immediately to the left of it to the left. The film should now rewind.
When the film is done rewinding, open the back via the sliding latch on the left side of the body with the gray button in the middle. Push the button, while sliding the latch down.
To insert film, place the cartridge in the same place and orientation as the old roll, and pull the leader over to the red dot on the bottom right of the film compartment, and close the back. it should advance to the first frame if done correctly, or blink 0 if done wrong.
If you need anymore assistance, contact me via email cwrrailfan at yahoo dot com
Have Fun with your 7000!
Mar 11, 2009 | Minolta Maxxum 7000 35mm SLR Camera
The drivers side door won't close.
open the door , look at the latch on the door , as it get older and non lubricated , the latch can stick in the locked position , i,m going to draw a picture .
when the door is open it should look like the picture , i suggest your door is in the closed position and why it bounces off as you say , take a , lets say a screw driver stick it in where the little lever thats sticking up , push the door open button on the outside door handle , pry that lever forward , if successful try it , and lubricate it , hope my barbaric picture gets the point across .
Jan 05, 2009 | 1995 Jeep Grand Cherokee
Canon s5 is it will not power up
OK, since I'm an engineer I couldnt resist the temptation to open up the beast for more than 5 minutes so I opened it up to see what's inside (I can't recommend this due to the small screws any tiny delicate connectors inside). Along the way I discovered and fixed the problem.
As is typical for broken appliances usually the primary method for succesful repair is: open, vacuum clean, close. And otherwise see what happens along the way.
What I found in my case is very simple: when I close the battery compartment latch you are supposed to hear two sort of "clicking" sounds. The first one is a obvious one which happens when the plastic of the lid snaps into the plastic latches on the camera body, it is a clearly audible plastic-on-plastic like clicking sound. The second clicking sound, which was the missing link to make my camera work, is a higher pitched, lower volume, metal spring like snapping sound. I don't know where that latch occurs but it only happens when I push the plastic lid all the way in even after it seems it is already fully secure. Without that second metal-like click my camera won't power on. I can reproduce the problem by closing the battery lid but not to the point of the second "click".
So my simple solution is, push or jam your battery lid all the way in until you hear the metal-spring like clicking sound. Worked for me, hopefully works for you too.
Dec 05, 2008 | Canon PowerShot S5 IS Digital Camera
Compartment door will not shut properly, camera will come on
Drill 2 tiny holes, large enough to insert thin paper clip wire. One hole is drilled in the battery compartment door, close to the sidewall but in between the 2 adjacent batteries.
Drill second hole in battery case by first peeling back the ruberized coating slighty. This hole should be adjacent or sighted in line with the first hole. In each case, allow enough in tact plastic door or case so that it can withstand the pressure of a tightened piece of wire. Insert batteries. Then insert wire carefully tto penetrate both holes. Press down hard on battery compartment door and carefully twist the 2 ends of the inserted paper clip wire to secure the compartment door tightly. The one drawback is that each time you wish to change batteries, you will have to follow the above procedure.Don't know of any recalls on this condition.
Sy25 [email protected].
Nov 21, 2008 | Nikon Coolpix 990 Digital Camera
Good Luck! =)
Mar 18, 2008 | Sony Cyber-Shot DSC-W1 Digital Camera
Nikon Coolpix 2100/3100/3200 battery compartment door latch broken (again)
I just purchased a new battery door for $15 with shipping from nikon. They sent a simple assembly diagram and I was able to replace the door in 30 minutes. I used a dremel to cut the old door off, but you dont have to do that. I got a little impatient.
Just buy the plastic piece and u can reuse the metal parts for your old battery door.
Oct 15, 2007 | Nikon Coolpix 3200 Digital Camera
Sony Cyber-Shot DSC-W1 Digital Camera Logo
163 people viewed this question
Top Sony Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Harrie
NOEL
NOEL
Are you a Sony Camera Expert? Answer questions, earn points and help others
