Question about Cobra Radio Communications
Hi i have a es880 echo chamber and need to wire it to a pama dm531 power mic and tristar 757 can anyone help?
Hello all ive acquired a es880 echo chamber but havent a scooby doo how to wire it im wanting to connect a pama power mic to the unit and a tristar 747 to the lead all the wires are disconnected on the socket side 1 blue wire 1 black wire 1 white and shield in gray sleeve 1 white and shield in white sleeve the blue and black wires come from the lead that goes to the radio the other wires are connected in the unit any advice will br greatly appreciated
Posted by Stuart Craig on
DROPNDEAL
    Top Expert:
  • Cobra Master
  • 2,931 Answers
Posted on Feb 02, 2018
4 Related Answers
Anonymous
  • 170 Answers
SOURCE: Diesel #8-32 echo power mics
cobra 4 pin is pin1= shield, pin2= mic audio (usually the shield is wrapped around the mic audio wire).pin 3= transmit or push to talk usually red or white whichever isnt wrapped with the shield, and pin4 = receive or speaker complete
5 pin cobra=1-Audio 2- Shield 3-Receive 4-Switching Wire 5-Transmit, you can jump pins 4 and two
Posted on Dec 28, 2008
Anonymous
  • 156 Answers
SOURCE: Wiring Johnson Microphone to cobra 29 CB Radio
Use trial and error systemathically. If still refuses to work, mike and radio aren't compatibles.
Posted on Nov 23, 2009
Anonymous
  • 12 Answers
SOURCE: I have a cobra 148gtl with 5 pin side plug for
ALLways start with ground. Find ground on radio pin with ohm meter. EVERY thing operates off ground. Once you find ground on radio....solder your ground wire on mike cord to corresponding # on mike jack. Once you have ground on proper pin then all else is elementary......use ohm meter to see which wires are TX and RX on mike.....last wire is audio wire.
Posted on Jan 25, 2010
JOHN BABA
  • 1274 Answers
SOURCE: Hi all, I am trying to wire a dm-452 echo / power
Pin-1,shield and black, Pin-2,white, Pin-3, red Pin-4,blue.
Posted on Mar 30, 2010
I want to wire my superstar dm452 power echo mic to my realistic trc 465 am ssb and need to know what color goes to what pin?
its a 5 pin which all radshack radios are and they are all,99% anyway, wired the same . So take an old radshak mic apart at the plug and see how it is wired then experiment from there.
Apr 07, 2015 | Workman Publishing Workman DM-452-5 model...
Can you help need the wiring for astatic silver eagle mic to wire up to the yeasu ft-757-gx radio
The best info I can find iis
radio mic
pin5 blue mic ground
pin6 red ptt
pin7 screen
pin 8 white mic
Jan 30, 2015 | Astatic Radio Communications
Have got a es 880 echo chamber need to find out which wires do what (white screen blue and black) hope some one can help many thanks
Got a es880 echo chamber cybernet wirerd i want to wier to my super star 3900crt whats the wiering code help please thanks Tom
Sep 05, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
Mic Echoes
Echo is caused by a number of variables. Are you in a large room with mic extended away from you? Mic too far away will create echo. Also try turning down the gain for the mic
Jan 22, 2010 | Dynex Voice-Certified PC Desktop...
How to wire a power echo mic up theres 5 wires and 4 oins
I suggest buying a 5 pin to 4 pin adapter. Ebay has them for $6. I would go chopping wires on the mic. Cobra 29 ltd is a nice radio. Have one myself.
Apr 25, 2009 | Cobra 29 LTD CB Radio
Headset and mic problem
may be codec issue unistall the sound card from device manager and reboot the pc then test again.
Jan 02, 2009 | Logitech ClearChat Stereo Headset Headset
Dec 21, 2008 | Magnum 257 CB Radio
Cobra 200
Hello Jim. These radios do not work well with any power mic including the power echo mics because they have good modulation boards in them. But if you still want to try then check http://www.cbtricks.com/radios/cobra/200gtl_dx/index.htm
Mar 26, 2008 | Cobra 200 GTL DX 4-Channels Base CB Radio
Radio Communications Logo
126 people viewed this question
Top Cobra Radio Communications Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
