These are operating instructions for an SV F-IAGAG (Sergio Valente) watch.
There are four buttons on the watch.
A: upper left
B: lower left
C: upper right
D: lower right
Pressing A turns on the watch face backlight.
Pressing B changes the mode.
From the normal time display mode, one press of B enters the stopwatch mode. In this mode, pressing C will start the stopwatch time count. Pressing C again will stop the count. Each additional press of C will start/stop the count. While the count is proceeding, pressing D will freeze the display of stopwatch time, yet the count will continue. Pressing D again will cause the display to begin updating with the running count. Each press of D will freeze/unfreeze the display update. When the count is stopped (with a press of C), pressing D will reset the count to zero. From this mode, press B again to return to time display mode.
From the normal time display mode, two presses of B enters the alarm time set mode. In this mode, either the hour or minute portion of the time display will be flashing. That which is flashing can be changed by pressing C. Pressing D will switch to the other portion (hours or minutes). Any time the alarm mode is entered and a change is made, the alarm is set to "on". This is indicated by a check mark in the circle display next to the "9" on the watch face. The alarm can be toggled "on" and "off" from the normal time display mode by holding down button D and pressing button C. Return to the normal time display mode by pressing button B while in the alarm time set mode.
From the normal time display mode, three presses of B enters the time set mode. Upon first entering this mode, the seconds display in the circle near the watch face "3" will be flashing. Pressing button C will reset the seconds to zero. Each press of the D button will advance to a different value field for adjustment. The field of adjustment will be flashing. The sequence of fields is (seconds - minutes - hours - date day - date month - date day). Pressing C will change the value. When adjusting the hours, both 24hr format, and 12hr AM/PM format is available. Each press of button C will advance the hour value. The sequence of 24hr format will be indicated with an "H" in the "seconds" circle (near the watch face "3"). After hour value 24 of the 24hr format, the next hour is a "12" value, with an "A" in the seconds circle. Twelve presses of button C will step through the AM hour values and present an "12" value with a "P" in the seconds circle. Twelve more presses advances through the PM hour values and returns to the 24hr format. Pressing button B will return to time display mode.
Pressing button C while holding down button D will toggle the alarm "on/off" state. The "on" state is indicated with a check mark in the display circle next to the "9" on the watch face.
