I bought one at a thrift shop, but there's not a filter. Does it have one or not?
This humidifier is AMAZING. I’m a huge fan of using essential oils (lavender, lemongrass, spruce, rose, sandalwood etc) and I picked this up from a thrift shop, added some essential oils to the water and my house smells wonderful.
Essential oil diffusers are virtually the same thing design wise except cost a fortune. This is my best diffuser! I paid $10 for it and it works so good, throws off a ton of mist which I love (it’s so dry here) and I will enjoy owning this unit for years to come. Only thing is to gently clean the little ionizer part with the brush gently and keep it clean. Also..this unit unlike newer ones does NOT shut off automatically so keep an eye on it. Running it dry might cause it to burn out.
SOURCE: sunbeam ultrasonic cool mist humidifer model 700
The Problem is minerals in the water. Impeller and ultrasonic designs send these minerals into the air. If the water in your area contains a lot of minerals, you will notice them as dust. The EPA does not issue health warnings about minerals in the air, but does recommend using low-mineral water (such as distilled water) in your humidifier. Many ultrasonic models feature a demineralization cartridge that filters minerals out of the water to prevent the dust.
Good Luck.
SOURCE: Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
DO NOT LET WATER SIT IN TANK FOR LONG. THIS CAN ENCOURAGE BACTERIAL GROWTH.
Place unit on level surface away from direct sunlight.
DO NOT ADD MEDICATION OF ANY TYPE INTO THE NOZZLE, BASE, OR WATER TANK.
ALWAYS LEAVE ROOM DOOR PARTLY OPEN. DO NOT MOVE, TILT, OR EMPTY WHILE OPERATING.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
SOURCE: How do I change the
Turn the unit off and disconnect from the electrical
outlet.
2. Remove the tank from the housing.
3. Unlock the housing from the base by turning the lock
knob to the unlocked position.
4. Lift the housing straight up and place to the side.
5. Unlock the wick holder from the base by turning the lock
6. Remove the wicks from the wick holder.
7. Follow the weekly cleaning instructions.
8. Insert new filters into the wick holder and lock the wick
holder back onto the base.
9. Replace the housing onto the base and lock it into place.
10. Fill the tank and place back into housing.
11. Repeat Operating Instructions.
It will take about 30 minutes for the humidifier to reach
