SOURCE: sony handycam DCR-DVD108 - - error e:61:11
The abnormalities in initialization of the focus lens and the abnormalities in initialization of the zoom lens occurred simultaneously(FOCUS OR ZOOM SECTION NOT WORKING PROPERLY)
SOURCE: sony handycam dcr-trv19e mini
Thank for that qestion,
At this point, if you are a lay-man or person you need to eject the camcorder and aloud it open and put under sun light for an hour. If its do the same, take it to a technicain.
but if you are a technicain, dismantle the camcorder and put the machinusm under hot tempreture for 20minute. then mount it back and your camcorder will be fine.
I have done this time and again and it has never fail me.
I hope you will smile.
SOURCE: Driver software of Sony Handycam DCR HC30E for windows vista
http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DRIVER&PRODTYPE=37
you only need to find which one is your model.
hope it works
pls rate this.
SOURCE: SONY HANDYCAM DCR-DVD105 ERROR MSG C:13:02
Try to use a cotton swap to 1st clean the recording lens or blow gently on it. Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
SOURCE: Sony Handycam DCR-TRV145E CCD Image Sensor Fitting
ive had my camcord for a while but not been able to use it much as when i record it is black cant see what im recording its still new in box every think else works is this a problem with this make!!!!!
