SOURCE: honda generator em 1800
Honda generators are very reliable and are easy to adjust. The best way to check for proper output is to use a meter that can check cycles and voltage. Set meter to htz or freq and adjust the engine governor to 60 cycles. When the engine is turning 3600 rpm it is at max power and the generator may be producing ac voltage ranging from 115 to 125 at 60 cycles. When you draw power from the generator the engine governor will try to overcome the stress and maintain 3600 rpm. The engine must be well maintained to produce full power. Service oil, filter, plug and valve adjustment. Some engines have a spark arrester installed in the muffler that may become blocked with carbon. If engine is producing full power and voltage/amps is low then check brushes, capacitors, and/ or voltage regulator. Most problems occur when too much power is requested from rated generator. Example, trying to connect an 1800 watt air compressor to generator. The compressor may draw double the stated wattage upon starting and cycling. For longest generator life, It is best to use only 75% of rated output. On an 1800 watt generator use max wattage 1350. If you actually need to use 1800 watts then the best generator would be a 2500 watt. enjoy
SOURCE: My generator does not throttle up automatically
I've posted an answer to a somewhat related problem here
but you should read that later as I think you want a better idea of how the whole thing works.
Inside the control box on the generator the power leads get connected so that we have an L1, L2, and N feed wire with L1 and L2 being the 2 "hot" wires. Both of the hot wires pass thru a small current transformer (one wire in each direction) and then go to the various outlets in the output panel. The current transformer makes a signal whenever current is drawn thru either wire.
The current transformer sends its signal to an idle control circuit on a printed circuit board inside the control box. The other wires from this board go to the idle control switch, the power regulator/exciter board, and the idle control solenoid. The idle control board uses the DC voltage it gets from the regulator/exciter to energize the idle control solenoid if the idle control switch isn't in the "off" position and no signal has come from the current transformer for a sufficient time. The idle control solenoid acts to pull the throttle assembly until the throttle bell crank hits the idle adjustment screw (whew!)
Troubleshoot it like this:
1 - Does the engine start at governed speed and then idle down or does it start at idle? If it starts at idle, or seems to idle down faster than usual, something might be amiss in the works.
2 - When you turn the idle control switch to "off" does the engine rev up to governed speed immediately? If not there is almost certainly something ugly going on.
3 - With the idle control solenoid unplugged from the idle control board does the engine rev up to governed speed? If it won't you need to check to see if the plunger is stuck on the idle control solenoid. Some solenoids also have an adjustment that can get loose, check the voltage on the wires coming out of the idle control board if you're in doubt about its being energized or not.
4 - If the generator revs up when you turn the idle control off, but won't do it automatically when current is drawn with it turned on you need to check the current transformer with an ohm meter. Even though this is an AC signal you should mark the leads when you take them off so that they go back from whence they came - it's a noise thing ;-) Little square current transformers in Coleman Powermates are usually somewhere in the 1 - 2 Kohm range, failures are typically that the coil opens up.
Rank me when you've completed repairs?
Carl
SOURCE: Honda EM 2500 Generator
I posted a general tutorial on troubleshooting this problem here.
Rate me?
Carl
The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
