Im wanting to crack open a myx 251 d AMP AND use a test light to see if anything is fried
SOURCE: my 7801 doesnt turn on
check pwm circuit amps turn on with 3-4 volts on mosfet gates ic 494, 5252or 555 controll these.hit me up for more
SOURCE: MTX 1501 SCHEMATIC DIAGRAM
MTX never released any of their schematics.
What sort of problem are you having with it?
SOURCE: Everything works fine but my amp light is red.
if its not coming on it usually means you have a bad ground if it works for a little while then does it then its over heating and you will need to get a fan
SOURCE: mtx thunder 1500 watt amp no sound
Even if there is no visible damage, it could be that one of the transistors is blown, Use a multimeter to check the resistance of the transistors.
