251 d mtx car audio amp wire schematics. i can`t get any power out of amp does not smell burnt.its getting power up to thw fuse.when i have amp wired to car batterey and i pull amp fuse and reinstall amp fuse im gatting a spark and fuse maks a little popping sound.Fuse dont fry but im getting nothing from there.How do i fix it
SOURCE: mtx 1501d no sound
There are a number of things that can cause it to act as you described. Have you pulled the covers off of it yet to see if you can see any problems?
If you do, disconnect power from it and don't touch ANYTHING on the board when ANY of the 3 LEDs (2 are not visible from the outside) are lit.
SOURCE: MTX 1501 SCHEMATIC DIAGRAM
MTX never released any of their schematics.
What sort of problem are you having with it?
SOURCE: MTX Terminator Amp...Red light comes on when it should be green.
its just a power light to let you know its on
SOURCE: mtx thunder 1500 watt amp no sound
Even if there is no visible damage, it could be that one of the transistors is blown, Use a multimeter to check the resistance of the transistors.
SOURCE: I recently purchased the mtx
If none of the lights are coming on for the amp then the amp is not getting power and/or ground. Check the connections. Check the fuses. Or the amp is no good.
