Everything turns on and lights up but no collection of dust on the metal strips
Larry, since this unit is electrostatic, you may or may not hear little crackles of sparks when it is operational. You should, however, smell a very faint odor of ozone when it is running properly. If you do not hear any sounds from the electrical plates and the air coming out of the unit does not have a little different smell than the air in the rest of the room, then the unit is not functioning properly. In my research of these units, I did see references to replacing the metal fins being required as some claimed they were an consumable element to the purifier and needed periodic replacement to function properly. However, nothing in the owner's manual says they are. It simply says to carefully clean them to avoid damaging the fins or plastic insulation on them.
Other factors to check include:
Making sure the unit has at least 12" of open space behind it.
Making sure there is 36" of open space in front of it.
Give time for dust to accumulate. The manual states that you should check the collection fins after a couple of days to see how much dust has accumulated since cleaning schedules will vary greatly depending on how dusty your home is. Dust collection may take days to start to appear.
Make sure the DRYING CYCLE light is not on when the unit is operating. This protection system is designed to remove electrical power from the fins if humidity is detected (which can easily be the case since you are advised to wash the fins in water to clean them).
If the DRYING CYCLE light is not on, you have plenty of air space around the unit, and after days you still do not see anything on the fins, then chances are the issue is internal and will require repair or replacement of parts. Be advised that this unit is no longer made and has no manufacturer supported service or parts availability. Further diagnosis and repair could quickly get costly and in most cases, you are probably better off replacing the unit.
SOURCE: Honeywell HFD 135 FAN BLADES DIRTY
I used a can of compressed air to clean my fan blades and this did the job. I bought a 6-pack of 3M Dust Remover at Sams Club to save money. Hope this helps.
George
SOURCE: Ionic Breeze Hybrid GP air purifier only 1/2 grid gets dirty.
I have been doing research on this unit. I read that only every other grill is suppose to collect. The remaining grills increase the electrostatic charge making the collection plates, the ones that get dirty more effective. So the bottom line is there is nothing wrong with your unit.
SOURCE: We bought this model, I removed and cleaned the
There is dirt on the inside of the unit. Remove the metal plates and turn unit upside down and gently shake to release the dirt built up in the bottom, also check metal contact near the base of the unit. If it isn't clean the machine cannot make the magnetic connection necessary for operation. Use a q-tip and 91% Isopropal Alcohol NOT rubbing alcohol. This should get your Ionic Breeze going.
