SOURCE: Verifone 3730-trouble staying connected over Qwest TDM network
In the verifone file groups you have to delete *ZT and *ZRESP fields add *ZB Value is 1000 and *ZINIT Value to AT%C1\N3\V2.Let me know if you need help.
www.greenlightpayments.com x 105
SOURCE: my Omni 3730/3730LE VeriFone printer does not
Where can I buy an new ink roller only for the verifone omni 3730 le?
SOURCE: Verifone Omni 3730 says "Bad
The "RTC chip" is an integrated circuit that provides the R(eal) T(ime) C(lock) functionality. If your device cannot keep the correct date & time, it's time to replace it.
To reboot, turn the device off, and then remove the battery.
Wait 60 seconds, reinsert the battery, and turn the device on.
SOURCE: verifone omni 3750
here's some passwords you can Try: 1, 0000, 1234, 1701, 1739, 000000, 12345, 998877, 123456, 752036, 23378463, 45803155, 53664337, 1[Alpha][Alpha]66831, 6[Alpha]78727[Alpha][Alpha], Hope this help if not call us @ 775- 358-2922 : - )
SOURCE: change battery in verifone 3730
battery is located inside the machine. You need to open the plastic case to see it. 7 screws holding the case together, but be careful not to break the case, multiple sensors inside the unit, don't loose it. If you still needs help, call us at (775) 358-2922 ask for Randy. http://freshpoint.org
