Water valves replaced as the ice maker valve had 3.2 ohm resistance (shorted). Still no water delivery. All other functions of the maker are normal.
SOURCE: whirlpool ice cube maker not functioning
Comment regarding catriver Aug 18 post: Shorting L&V caused valve to work I believe, at least I think I heard it operate, but shorting T&H did not cause gear to move. So does that indicste a different problem? Still no ice. JimB
SOURCE: ICE MAKER NOT WORKING
Yes, the ice maker controls the water valve. First check that there is water in the ice maker trays. If there is your valve is not the problem. If not, loosen the fitting on the water line that leads to the water solenoid valve. If you do not find water, check your manual valve that taps into the main water line. If you do have water, it may be that the water inlet above and behind your ice maker is frozen. You can thaw it out with a hair dryer and see if that is the problem. If this model dispenses water through the door, you can find the water solenoid valve behind the unit near the floor and reverse the two plugs on the solenoids. Place a paper towel in the water inlet tube that channels the water into your ice maker. Close the coor and press the water dispenser for 3 seconds. Open the door and see if the paper towel is wet. If it is, the water solenoid is fine. You can also remove the front of the ice maker and put an insulated jumper wire between the T and H test points to see if the unit ice maker will go through its cycle.
SOURCE: Ice maker not working
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
SOURCE: whirlpool ice maker
this is a hard one to diag in person, let alone via email. you know your not getting water to the ice maker, problem is finding out why, ther is (or should be) a tech sheet behind the kickplate of this unit with a little trouble shooter and diag procedure for the ice maker. folded little blue/and or brown paper.
1. is the water line leading from the valve to the ice maker fill clogged/frozen??? pulll the machine out and youll see the line leadding to the top corner of freezer, disconnect that line and try to blow though to the insde of freezer, should blow withno resistance. if so your good if not youll need to thaw that line
2. is the red light blinking on the inside of door. its a sensor for the ice maker if its faulty you wont get ice either.With the flapper on rt wall of freezer depressed the light should remain on solid, if continues to blink a pattern, 1 and 1 quick blinks, 1 and them 2 quick blinks, youll need to replce the electronics
3. is the water valve itself just not sending water to the ice maker. its a dual vavle 1/2 does water and the other half feeds the ice maker . generallly youll hear the valve being energized, just no water coming through
4. ice maker itself can be damaged and not calling for water at all.a pretty common issue with these electonic control ice makers is the center gear actually over torques itself and winds up snapping itself(at least the tabs that hold ino place snap anyway). gaining acess to the face of the ice maker will tell this.
while looking at the exposed from\nt of ice maker you should see the center gear adn the 2 tabs holding the gear on as well. ther shoud be a SMALL but definite space betwwen the 2 tabs in middle of center gear, as if it were pressed on and the tabs spread back open to hold onto the gear. if 1 of the tabs is cracked or the gear isnot mounted correctly because of the tabs, you best bet is to replace the ice maker assy
GOOD LUCK
SOURCE: ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Click here=>
Whirlpool's Ice Maker Harvest Cycle
most of the information you are looking for is on the page above. I will let
you begin by going to that link and saving the Whirlpool Ice Maker
Troubleshooting PDF. Once you read over that material and are able to use an
ohm meter we will move to the test points behind the ice makers front cover.
Ice Maker have about a five year average life cycle and many times it is more cost
effective if you replace the=> D7824706Q Ice Maker Assembly or click
here=> D7824706Q Ice Maker Assembly In the clip below you basically have all the
solutions in this one You-Tube Movie=> Ice Maker Repair I believe this is one of
the better Whirlpool Ice Maker related video's and covers most all of what you
need answered. I will be here to answer any questions. Checking the ice maker
mold heater by testing the L and H test points (should show about 72 ohms of
resistance) Testing the Ice Maker Timer L and M test points should show around
4400 ohms of resistance Motor You also can answer from the ice maker by testing
just what condition your water control valve coil windings are by placing the
test probes in the N and V test points where you should get between 150 and 350
ohms of resistance. I will be here to answer any questions you may have, If
this solution is helpful please rate my solution, Thanks Sea
Breeze
as is the=> D7824706Q Ice Maker Module Whirlpool now owns Amana, Maytag, Jenn-Air and Samsung will not let me post their manuals to the public. I can answer your questions as need so If you need more answers or diagrams or photos Click Here=> Sea Breeze If you have any questions please ask, Thanks, Sea Breeze
Amana DRS2660BW Wiring Diagram
Amana DRS2660BW Ice Maker Parts Breakdown
