Question about HEWLETT-PACKARD Office Equipment & Supplies
SOURCE: AC/DC power supply
YOU CAN USE ANY AC ADAPTER THATS 3VOLTS 1500mAh OR 1.5A WHICH MEANS THE SAME THING IF YOU GO TO YOUR LOCAL ELECTRONIS STORE AND TELL THEM THIS THEY SHOULD BE ABLE TO DIRECT YOU TO THE RIGHT ONE
Posted on Sep 04, 2005
SOURCE: DC power supply HP 6654A
This indicates a failure during Power-on Self test that there is a fault with the DACS or secondary VDAC/IDAC readback.
If a simple on/off cycle of your power supply doesn't resolve the problem, your supply will require servicing.
Posted on Feb 11, 2008
SOURCE: lost power supply
If the desktop charger is the version that can accommodate two radios simultaneously similar to the T5000, then the AC wall adapter or the power supply is 9 volts AC.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 26, 2008
SOURCE: Unsure about power supply
Don't know if you've got round this by now but the supply needs to be 12v 1A with the inner positive
Posted on Apr 24, 2009
SOURCE: my hp pavilion f1703 does'nt power on checked
Common problem: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/
Posted on Feb 19, 2010
Apr 25, 2014 | HP Pavilion a1253w Notebook
57.4 Main fan error
Hi I hope this will help
The text come from the hp manual
good luck Ian
Q2431-90912 Chapter 7 Troubleshooting 287
57.X
PRINTER ERROR
To continue turn off then on
or
57.3
EP FAN FAILURE
or
57.4
MAIN FAN FAILURE
A printer fan is not functioning.
X Description
3 EP cartridge fan, right side
(LJ 4300 only)
4 Main cooling fan, left side
Turn the printer off and then on.
57.3 Cartridge fan error (F2)
1. Reconnect the connector
between the fan and the
DC controller PCA
(location J78).
2. Replace the fan. See "Cooling
fan (right side;
HP LaserJet 4300 series
printer only)" on page 170.
3. Replace the
DC controller PCA. See
"DC controller PCA" on
page 181.
57.4 Main fan error (F1)
power supply.
2. Verify that the ribbon cables
are fully seated in the
connectors on the
DC controller PCA.
3. Replace the fan. See "Main
cooling fan (left side)" on
page 168.
4. Replace the power supply.
See "Power supply" on
page 188.
5. Replace the
page 181.
57.7
DUPLEX FAN FAILURE
The cooling fan in the optional
duplexer is not functioning.
1. Turn the printer off and then
on.
2. Replace the duplexer.
Mar 25, 2011 | HP LaserJet 4250dtn Printer
Sep 17, 2010 | HP Pavilion dv2500t Notebook
Dec 01, 2009 | HP Computers & Internet
Jul 27, 2009 | HP DeskJet 9800 InkJet Printer
Jul 12, 2009 | HP Pavilion dv6000t Notebook
Jan 27, 2009 | HP (D6021-63034) Fan Assembly
Jan 22, 2009 | Office Equipment & Supplies
Dec 21, 2008 | HP Scanjet 4400c Flatbed Scanner
Nov 12, 2007 | Computers & Internet
Mar 25, 2017 | HEWLETT-PACKARD Officejet 4500 All-in-One...
