Bosch Tassimo TAS4511UC Coffee Maker Logo
A
Anonymous Posted on Jan 06, 2012
Bosch tassimo t46 coffee maker - Bosch Tassimo TAS4511UC Coffee Maker
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 04, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1140
Points
I have a problem with my bosch t46, I just bought it in Canada and returned to Aussie yesterday, when I plug it in all good orange light place disc in the green light comes on, but when i press and hold button both bottom red lights flash?
Any ideas what it could be very frustrating Thanks in Advance
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Jan 23, 2009
SOURCE: NOT SO GREAT COFFEE GROUNDS!
Might there be some stuff crusting the dispanser vent? Did you clean it regularly? If you've not done that, this is what you do:
1) Open up the lid where the T-Disc is supposed to go.
2) Take out any moveable (not breakable) object, for instance the thing that punctuates the T-Disc(its made of two parts stuck together) and the T-Disc holder.
3) Take 'em apart and put 'em into your dishwasher or wash it by hand.
4) Wipe the entire T-disc area with a damp cloth, make sure nothing stays there that isn't supposed to be there.
5) Put the removed and cleaned parts back very carefully and watch out that they are exactly in place, if in doubt wheter they are fitted correctly, just shake them a little. There should be no movement other than up and down.
6) Enjoy your coffee!
Anonymous
  • Posted on Jul 02, 2008
SOURCE: manual for Braun Tassimo TA1400 CoffeeMaker.
I found a website under Braun that had the operating manual in pdf.
Anonymous
  • 4 Answers
  • Posted on Jul 07, 2008
SOURCE: all lights are blinking on
One of four things possible here 1: Low water level in container. 2: no disc inserted. 3: disc incorectly inserted. or 4: unit has an internal malfunction, before you send it back, descale unit with scaler and flush clean. All lights still flashing call Tassimo and send it back for repair.
Jim.
Anonymous
  • 26 Answers
  • Posted on Jul 12, 2009
SOURCE: hi , i have had a Tassimo coffee maker for 6 monts
Your thermostatic control went bad.
Anonymous
  • Posted on Nov 20, 2009
SOURCE: Tassimo machine leaking water underneath
I'm having the same problem with my machine. I rang the Tassimo careline and they told me to descale the machine but, so far, this has only made matters worse. I'm now going to take it back to where I got it from because it's still within its warranty.
How do you descale a Bosch Tassimo coffee maker?
First see this:
descale Bosch Tassimo Google Search
Then see THIS for specifics (he said with a smile):
Tassimo descaling How to
ANTHONY!
(Say Thank You!)
1helpful
Bosch tassimo coffee maker What is the yellow disc for where you place the coffee pod? Also what is the digital piece on the lid for? If for size of coffee cup fill , how do you adjust it?????
Hi The yellow disk is used when cleaning the coffee machine and the size for cups is usually on the tassimo pack at the back.
The "digital piece" is a bar code for the discs.Hope that helps? ps,
Go to Tassimo site for info
The lid won't open to get the used coffee pod out. It seems to be stuck.
Customer questions and answers for Bosch TASSIMO T10
answers.tassimodirect.com/answers/.../bosch-tassimo.../questions.htm?...
The TASSIMO T10 Single Cup Brewing System by Bosch brings the artistry ... the machine made some funny noises and now I cant open the lid to remove pod. ... When I went to remove the T-disc, the tassimo won't open so I cannot get it out.Missing: tas5542gb
Bosch Tassimo TAS4511UC Coffee Maker Open ... - Fixya
www.fixya.com > ... > Bosch Tassimo TAS4511UC Coffee Maker
Question about Bosch TASSIMO Coffee Makers & Espresso Machines ... colors, openthe lid, put disc with the cream in the machine and the green light won't come on, only the . ... Bosch Tassimo Tas5542gb Multi Hot Drinks Machine, Black.
Why has my Tassimo brewer stopped working?
www.coffeedetective.com/why-has-my-tassimo-brewer-stopped-working...
QUESTION: I have a problem with my Bosch Tassimo brewer. ... Now when I close the machine, I open it and remove that litte tin foil circle. ... Opened my new Tassimobrewer and won't brew and water dispenser leaking all over... an ... I have a problem with my tassimo coffee maker the lid wont lift up seems stuck any ideas ...Missing: tas5542gb
Descale T20 Bosch Tassimo
you need to use the cleaner disk (tucked into the back of the machine) and run through some of the cleaner solution. Then run though just water. Don't forget to store the cleaner disk back in the machine.
Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it
Bosch Tassimo T65 Repair Questions,... - Fixya
www.fixya.com > ... > Coffee Makers & Espresso... > Bosch > TASSIMO
0 Answers. Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it · Bosch Tassimo... ' Posted on Aug 23, 2014 ' Be the ...
Bosch TASSIMO red light water full Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/red_light_water.../tassimo
0 Answers. Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it. Aug 23, 2014 ' Coffee Makers & Espresso Machines.
Bosch TASSIMO cleaning condensation tray Unsolved ...
www.fixya.com/unsolved_problems/...condensation_tray/.../tassimo
My tassimo coffee maker is ruining the coffee it taste like water
i too had this problem BUT it was AFTER i descaled it and did the cleaning, now coffee tastes weak, and ive tried different discs (other coffees) and all come up weak.
Water won't heat up in my bosch tassimo coffee maker, what do I do?
I unfortunately got my vivy emesred in water. When I switch it on it stars brewing cold water splashing all over the place and does not stop!
Any idea how I can salvage the machine?
2answers
User instructions for Bosch Tassimo coffee maker type CTPM01
Here are the user instructions for the Bosch Tassimo coffee maker type CTPM01: Fill the water tank with fresh water. Turn on the coffee maker by pressing the power button. Wait for the indicator light to turn green. Place a T-Disc (coffee or other hot beverage) in the brewing unit. Press the start button to begin the brewing process. Wait for the brewing process to complete. Remove the cup and discard the used T-Disc. Repeat steps 4-7 to make additional cups of coffee or other hot beverages. Additional Tips: Always use fresh water when filling the water tank. Only use T-Discs designed for use with the Bosch Tassimo coffee maker. To descale the coffee maker, use the descaling T-Disc provided with the machine or a descaling solution recommended by the manufacturer. Regularly clean the brewing unit and other removable parts according to the manufacturer's instructions. Refer to the user manual for additional information and troubleshooting tips.
2helpful
Tassimo coffee maker part replacement
If your machine is made by Bosch then go to www.bosch-eshop.com where you can order spare parts online. I think the part number is 616231:Jet and is called a Tassimo piercing unit.
Top Bosch Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
David Kassin
David Kassin
vince
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
