Dehumidifiers Logo
A
Anonymous Posted on Jan 06, 2012
DeLonghi CF208 dehumidifier problems
Does not work in dehumidifier mode
3 Related Answers
Anonymous
  • 259 Answers
  • Posted on May 03, 2009
SOURCE: Dem 10 Delonghi Dehumidifier not working
have you tried turning it to a higher setting ??
Anonymous
  • 72 Answers
  • Posted on Jul 03, 2009
SOURCE: delonghi de400p dehumidifier does not work
if comp and fans running your out of freon or the compressor is not pumping more than likely out of freon and that means theres a leak in the sealed system high cost repair
Anonymous
  • Posted on Aug 12, 2009
SOURCE: Delonghi pac 160 ( with air condition & dehumidifier modes) pINGU
i would like to know if the =unit turns off when it get to the tempature that you put it at
I have a DeLonghi NF 90 air conditioner/dehumidifier. The dehumidifier does not appear to be working - first time I have tried to dehumidify. Have had this unit for about 8 years. Thanks, Niall
If the air conditioner works and is blowing out super chilled air, then the dehumidifier function should work. The function takes in warm moist air and passes it over plates which are marginally colder than the ambient air. The air condenses and drips into a collection tank, or some have drain hose for putting into a floor drain.
After 8 years, it may need service and gassing up, but you may also have drier air than you think. Whether is works in AC Mode is the key.
2answers
Delonghi 500p freezes up at bottom left of coil and then does not dehumidify
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
2answers
My 3-month old Delonghi 50 dehumidifier is leaking
Did you find the solution to your delonghi 50 pint issue? We have similar problem and No Manual - we are looking for manual too, any thoughts on where to find that too, please?
2helpful
Delonghi de400p dehumidifier does not work
Thanks
I went back and rechecked. If the fan mode is selected, you can only set the fan at one of the three speeds. If you leave it in the fan mode, the dehumidifier will not come on.
Once the fan speed is selected, it will run at that speed in the dehumidifier mode. The fan will keep running, even when the dehumidifier (compressor) shuts down.
The only way to get it to turn off is to use the clock setting, which either selects how long it stands-by before starting , or how long it will run before going back to stand-by. DeLonghi calls it "stand-by," we would call it "off." DeLonghi calls unplugged "off."
I've never turned mine to stand-by, because it will never get my entire house down to 30% humidity (I have it where my air handler returns air to the basement). I live in the greater DC Metro area, where 75% humidity is considered extremely dry.
Apparently the normal mode of operation is fan on unless awaiting a clock start, or encountering a clock shut-down; either condition puts it into the "stand-by" mode.
1helpful
DE 500P - Fan will not shut off
If you have the fan icon selected, it is supposed to run continuously. If you use the mode button (not the fan button) to change to relative humidity (the water drop icon), the fan should only run with the dehumidifier.
Top DeLonghi Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
