SOURCE: Pitco Fryer
The diagonals of quadrilateral ABCD intresect each otherat the point O such that AO/BO=CO/DO.Show that ABCD is a trapezium
SOURCE: pitco frialator
Is it doing more than lighting the pilot light? Or is the only action is the pilot light coming on, then off?
I would need to know more spacifically which model you had. Here is a list of manuals on the manufacturers web site so you can see for yourself.
http://www.pitco.com/doc_lib.htm
If I were to look at your unit, I would first look for, and see if there is a sensor (sometimes appears to resemble a piece of coat hanger sticking through some ceramic) that the flames will heat. The warming from the flames generates electricity. The electricity keeps the gas flowing. It is a safety device to keep your home/business from exploding from a build-up of unburnt gas.
Make sure the sensor is being hit by the flame. If it is, and the flame still goes out, then it just might be bad. I would imagine it would run about $20 for a replacement part.
if it works, great! If not, then you are only out $20.
SOURCE: Wiring diagrammed of Pitco model 7-2wkss
Sorry to break this to you but all pitco fryer model numbers start with an S, please make sure what manufacture this fryer is made by.
Thank You
SOURCE: comercial deep fryer pilot light goes out
This problem could be caused by a few different things. You should check the condition of your pilot and the thermocouple, if the pilot is weak due to being dirty you will not generate the optimum Millivolts to run the fryer, you may need to dissassemble and clean the pilot. The thermocouple needs to be correctly placed in the pilot assembly, if it has dropped down to where it is not in the flame it will not work correctly. You may need a new thermopile as it may not be generating millivolts as needed. Gas pressure can cause this as well, if the pilot goes out then the main burners come on you should check the gas pressure. One more thing to check is the hi-limit thermostat, if this is cutting out early your pilot will go out. Imperial uses a self-resetting limit, after a few minutes your fryer will relight and work until if cuts out again. If your fryer pilot stay on with the thermostat off for long periods of time and does not go out immediately when the burners come on and the pilot is clean, you may need a hi limit. This is a lot of info, I hope it helps.
