Question about Garmin Nuvi 1450T GPS Receiver
Garmin 1450t stuck in loader loading error after downloading maps
Purchased maps lifetime after download finished it went to loader loading and will not move
Posted by lawrence on
Desiree Rodriguez
    New Friend:
Please follow the instructions below to remove the "Loader Loading" message from the unit.
To fix this problem on Windows:
  1. With the nuvi powered off, press and hold the upper left hand corner of the touchscreen with your finger
  2. Continue to hold the touchscreen while pressing and releasing the power button on the device. The Garmin Logo should display
  3. Continue to hold the touchscreen while connecting the device to your computer
  4. After 30 seconds, the screen should flash white. At this point, release the touchscreen. A green progress bar should display on the device. After the progress bar completes (45-60 seconds), the device should go into Mass Storage mode
  5. Open the nuvi drive that appears in My Computer or Computer
  6. Locate the Voice folder and delete the extra Voice files that are not needed
  7. Type ".System" (without quotations) after the nuvi's letter in the address bar
    • For example, if your nuvi appears as E:\ then after typing ".System" in the address bar, it should look like this: E:\.System
  8. Locate the GUPDATE.GCD file and delete it
  9. Safely remove your device from your computer
After the corrupted update file has been removed, the device should work properly. Run the WebUpdater program to update the device's operating software.
To fix this problem on a Mac:
  4. After 30 seconds the screen should flash white. At this point, release the touchscreen. A green progress bar should display on the device. After the progress bar completes (45-60 seconds), the device should go into Mass Storage mode
  5. Open the nuvi drive that appears on the Desktop
  7. Click the GO menu at the top of the computer screen
  8. Click Go to Folder
  9. Type .System
  10. Click Go
  11. Locate the GUPDATE.GCD file and move it to your trash
  12. Empty the trash
  13. Eject the nuvi from the Mac
Posted on Jul 12, 2012
  • Mimi Murray May 01, 2013
    Worked after days of loading loader!!! thanks!!!!!!!
5 Related Answers
Anonymous
  • 199 Answers
SOURCE: have usa garmin nuvi 260 ,want to load austalia maps how?
well you need to update the firmware of your gps also call garmin customer support they are great tell them about the map, also the poor satelite cover might be because of your location or weather conditions
Posted on May 26, 2009
Anonymous
SOURCE: Garmin Nuvi 660 lost Europe maps
Eventually managed to speak to a man at Garmin who confirmed that it was not loading any European maps because it didn't have enough spare memory to load them all. He said that he would email me instructions for freeing up sufficient memory, the email never arrived but I decided to delet all the voice languages that were no use to me and all the other language 'help' files and tried again - it worked.
At no point did I get a 'insufficiant memory' warning, which would have been very helpful, nor is there any guidance for how much memory will be required when embarking on the update. Take note Garmin...
Posted on Feb 28, 2009
Anonymous
SOURCE: Garmin is stuck at loading maps
I had a 200 W Nuvi with the same problem. Luckily it happened with the first 3 months, so i could return it to Garmin under warranty for a free replacement
Posted on Jun 20, 2008
dennis bullard
  • 4090 Answers
SOURCE: garmin c330 stuck in "loader loading" mode. Can't turn it off.
stop it an try again iut doesnt take 10 hours. could be the website or a problem on your end
Posted on Jul 01, 2009
Joe Bannon
  • 1514 Answers
SOURCE: just bought garmin with lifetime
  1. To register your garmin connect it to your computer.
  2. Go to www.garmin.com
  3. Select your country from the drop-down list
  4. Click on the myGarmin tab at the top of the page
  5. Click on "Register your garmin product"
  6. Follow the prompts
You'll be asked to create a username and password. Keep them safe as you'll need them if you want to update maps at any stage.
Posted on Dec 05, 2010
When trying to put in an address the Garmin asks me for a country and then does not accept it after typing in the first letter. The other functions appear to be ok.
Hello
you need to update your map
Purchase your map updates (if necessary). You can purchase map updates for your Garmin Nuvi from the Garmin website. There are two basic options: a lifetime purchase or a one-time upgrade. The lifetime purchase gives you access to any new updates for the life of your device, while the one-time upgrade will provide you with the latest current maps, but you'll need to purchase again if you want to upgrade again later.
Make sure to log in with your myGarmin account before purchasing the map upgrade.
Connect your Garmin Nuvi to your computer via USB cable.
Open the "myGarmin" website and sign in with your Garmin account. Make sure to sign in with the account that you've purchased the map updates on.
Click the "myMaps" tab on the myGamrin dashboard. This will load a list of all of your purchased map upgrades.
Click the drop-down menu in the "Recent Map Purchases" section. Select your Garmin Nuvi from the list of devices.
Install the Garmin Communicator Plugin when prompted. This is required in order for the Garmin website to transfer the map files to your Gamrin software on your computer.
Download and install Garmin Express. This is the program that allows your computer to interact with your Garmin Nuvi.
Register your device in Garmin Express. If you haven't already registered your device, you'll be prompted to when you start Garmin Express. You'll need to register in order to update the maps.
Click the "Updates" tab in Garmin Express. This will show all of the available updates for your Nuvi, including the new map update you just purchased.
Click the "Show Details" option next to your Map Update. Click the "Install" button that appears. You will need to accept the agreement before the update installs.
Wait for the maps to download and install. Once you agree to the terms, the map update will begin downloading to Garmin Express, and will then be transferred to your Nuvi. This will likely take several minutes to complete.
unplug the Nuvi when the update is complete. The Nuvi will reboot and begin installing the updated software on the device. This may take another couple of minutes.
You can download garmin express here
http://software.garmin.com/en-US/express.html.
Apr 19, 2015 | Garmin Nuvi 610 GPS Receiver
How to update maps on gps
If you have lifetime maps, download Garmin Express for Windows or Mac, make sure GPS is fully charged, connect to computer. Let Garmin Express find GPS, do a complete backup, and then do a most recent map update. If you do not have lifetime maps you will have to purchase new maps from Garmin.
Mar 02, 2015 | Garmin Street Pilot c530 3.5 in. Car GPS...
How do i download maps on my nuvi
If you purchased the onetime or Lifetime map update just run Garmin Express, otherwise you may need to purchase those or plan on replacing the Garmin Device. If something happened to the original maps that were on there and you are too cheap to buy new ones, there is no way to load back on those old map files
Aug 03, 2014 | Garmin nuvi 200 Car GPS Receiver
Update my garmin nuvi 1250 gps `now`
If you are looking for map upgrades there are a couple options.
One is to purchase the update on DVD then load it to the unit.
Two Purchase a Lifetime Subscription to mapping which would allow you to update the GPS every 3 months.
You can also obtain a onetime update VIA download on Garmin.com. For best prices check www.gpscity.com
Oct 06, 2011 | Garmin nuvi 1250 Car GPS Receiver
No problem. just trying to download updates. 1 year
Garmin periodically releases updated maps for its GPSdevices. The my Garmin website offers convenient access for managing yourGarmin devices and finding the map updates you need. Garmin offers threeoptions for map updates: free download, single-purchase download or lifetimesubscription. Regardless of which option you choose, the process to downloadmap updates to your Garmin is the same.TOOLSAND INTRUCTION NEEDED TO SOLVE THE PROBLEM1 Connect your Garmin GPS to your computer. Locate theUSB ports on your computer and on your GPS. The GPS ports are typically on theback of the device and may be hidden by a protective cover or rubber cap. Plugone end of the USB cable into your computer and plug the other end of the USBcable into your GPS. Power on the GPS.2 Sign in to my Garmin(see Resources) with your username and password. If you do not have an account,click the Create New Account link to register your Garmin devices.3 Click the my Maps tab to display a list of yourregistered devices and their associated maps. Click the Map Downloads link todisplay a list of available map updates for your devices. Select PC Download orMac Download link.4 If you are alerted to run the Garmin CommunicatorPlug in, click Run. When the Plug in has detected your GPS and is ready todownload the map update, click the Launch Download Manager button.5 At the Save As prompt to save the map update, notethe location or select a new location to save the file. Click the Save button.6 When the Map Update file has finished downloading,click the Launch button.7 At the "Welcome to the Garmin Map Update"screen, click Next.8 After the Map Update USB Driver Check finishes, clickNext.9 Follow any instructions on the Map Update SuccessfulInstallation screen. Click Next.10 At the Software Data and License Agreement screen,select the checkbox to accept the agreement. Click Next.11 After the update installation finishes, click Finishto exit the program.12 Disconnect your GPS from your computer.Thanks.
Sep 18, 2011 | Garmin nuvi 255W GPS Receiver
Hi, hav a garmin nuvi. Has Garmap Africa series 2008 March edition. Is it possible to update the SD card via a free download. Tnx
For maps that came with a Garmin GPS - a map can be updated for free within 60 days after purchase. The purchase date is recorded after registering the device at MyGarmin.com or when the GPS detects movement above a certain speed. If the GPS is purchased with lifetime updates - it will be free throughout the lifetime of the Garmin GPS.
Just see what happens when registering the device at MyGarmin.com. A map update will show when there's one available for your Map version.
Jul 06, 2011 | Garmin GPS
I am trying to download map updates. I have purchased the lifetime update. The USB cable that I am using isn't a Garmin and it won't let me download maps. I didn't receive a cable with my GPS and am...
To download the latest unitsoftware visit Garmin website: www.garmin.com/webupdater First you have to set up an account at Garminusing the serial number on your GPS. Once you do that you can download firmwareupdates for free. After installing WebUpdater once from the Garminwebsite, perform all future software updates from your computer. Simply connectyour compatible Garmin device to your computer, then run WebUpdater from yourcomputer's "Start Menu" by selecting "Start","Programs", "Garmin", and finally "WebUpdater" REMEMBER: It takes hours todo a complete a map update.
You bought the Lifetime maps so you can download 4 times per year
By the way, the correct Garmin approved powerOR download cables are a must!! Does this help? Let us know. Thanks.
Feb 13, 2011 | Garmin nuvi 260W GPS Receiver
How do upload updated maps to my garmin660
go on garmin, connect your gps via usb , get map install program and you should be fine, works on any operating system
http://www8.garmin.com/support/mappingsw.jsp
Jul 01, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin c330 stuck in "loader loading" mode. Can't turn it off.
Jun 28, 2009 | Garmin StreetPilot C330 GPS Receiver
Cannot upload update
Problem resolved. It seems to have taken several hours for gps to update.
Thanks anyway.
Jul 21, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin Nuvi 1450T GPS Receiver Logo
2,212 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Sheldon Dedek
Janelle Schoonover
Janelle Schoonover
Are you a Garmin GPS Expert? Answer questions, earn points and help others
