When was the last time you cleaned out the dryer and the vent line?next time send the brand name and model number off of the machine,just cleaning off the lint filter isn't good enough,you should have the dryer taken apart,clean the duct that the filter slides into,vac out the cabinet where the motor is and if the vent line is a long run from the back of the dryer to the outside you can remove the vent line from the back of the dryer and blow it out with a leaf blower,as long as there isn't a cage or anything on the outside hood stick the leaf blower in the vent line and blow the lint outside,also while you have the vent line off the back start the dryer and make sure you feel air blowing out the back of the dryer,if it doesn't you could have a problem with the blower wheel the dryer should be cleaned out at least once a year if it's gas and once every 1 1/2 to 2 years if it's electric.hope this helps and good luck with your dryer.
