White lines (no ink)
A firmware update for your model addresses the print quality issues. Please visit the Lexmark website to download and install the Lexmark Pro900 Series Firmware Update. After successfully updating, run the Deep Clean Printhead function on your printer. Press the Ink Levels > More Options > Deep Clean Printhead. Then, try to print a document again to verify that the problem is fixed.
SOURCE: #5 black ink cartridge skips through the middle occasionally
Replacing the print head
The print head may need replacing if, after all print head and ink tank troubleshooting has been performed:
I hope it helps!!!
SOURCE: Light strips horizontally across page (blurred and faded stripes)
Ink cartridge has dried out.
SOURCE: streaky printing from canon pixma MP600
There is usually a maintenance button or similar in the "printer properties" dialog box to run a cleaning cycle."Right click" on your printer, select "properties", and you should see something. Try that.
Also, are these Original cartridges or compatibles / refills? Non originals can often cause image quality problems
SOURCE: Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
