Question about Rheem Water Heaters
I have a Rheem glas fury model 22-40 gas water - leaking I have a Rheem glas fury model 22-40 gas water heater.
1 Related Answer
HANK MCNEIL
  • 252 Answers
SOURCE: I have a Rheem glas fury model 22-40 gas water - leaking
once they leak it's time for a new water heater. ther is no way to repair a tank leak
Posted on Oct 23, 2009
Can't locate the year of manufacture of my Rheem Fury Model 29-40S-2
Generally the year of manufacture for Rheem is 3rd and 4th digit of serial number. 06 is 2006, 92 is 1992 etc.
Older gas water heaters are better than new ones, and easier to keep repaired and maintained.
http://waterheatertimer.org/How-to-maintain-water-heater.html
Regardless of age, the key factor is whether tank is rusted, or rusting.
Open drain valve and check if water is rusted.
http://waterheatertimer.org/Replace-anode-rod.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 18, 2012 | Rheem Fury 40 Gallon Natural Gas Water...
Hot water steam is coming out of the center hole located on the top of the Rheem fury 41v50n
Turn water heater off so it doesn't rupture.
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
Sounds like tank is rusted out.
http://waterheatertimer.org/Leaking-water-heater.html
Replace water heater. You can limp by for a while with rusted heater by turning it on for short periods when you need hot water. Then take time to find best deal on new heater.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Jul 11, 2011 | Rheem Water Heaters
The water leaked out overnight. We have not tried to start it again as it is still dripping water. We have a rheemglas Fury Model # 22-40 natural gas.
Open following link to troubleshoot cause and solutions for leaking water heater:
Rusted water heater must be replaced.
For money-saving water heater information:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 28, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
I just bought a house, and the water heater instructions posted on the water heater is all covered up by the earthquake straps! The earthquake straps are a requirement in California, I can't remove them....
1) Model 41VR50N is Rheem fury gas water heater.
Look on tank label, the second 2 digits of serial number are year of manufacture.
2) Rheem does not show that specific model number, but has generic manuals for Fury series:
Open link to read about Fury series, and access brochures and manuals.
http://www.rheem.com/product.aspx?id=CC643E03-4C15-4775-B139-E504A95651F7
3) Sample manual for Fury appears on following link:
http://globalimageserver.com/fetchDocument.aspx?id=01091171-3bac-4cb9-a0a8-a11aac3bd668
4) Rheem phone number: 1-800-432-8373
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Jan 30, 2011 | Rheem Water Heaters
Rheem glas fury water heater rattling
Thermostat may be heating element hotter than normal causing a change in temperature causing the noise. You could try adjusting temp down a little on thermostat. It sounds like it's getting the water very hot and thermostat may not be working correctly.
May 21, 2010 | Rheem 81VP6S/430126 Water Heater
Does the Rheem Fury model 22V50F1 qualify for an energy tax credit?
Unfortunately, no... According to the Rheem website, the Rheem Fury model 22V50F1 has an energy factor of 0.58:
In order to qualify for the credit, the energy factor must be 0.82 or greater...
Jan 31, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Dear Hank McNeal; I have successfully used a "boiler plug" to seal a water heater tank leak in 2007. It was a 100 gallon electric commercial hotel unit. To this day it's still in use. It depends where the leak is located....Predrilling the leak is necessary to be sure the plug will ernguage it's threads into good material... Start as small as possible, then use the best suited plug. they come in an assortment of sizes. rheem-glas-fury-model-22-40-gas-water-qbzdprdp3yetvbzozs4dsujq-4-0.jpg
Oct 23, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water Heaters Logo
41 people viewed this question
Top Rheem Water Heaters Experts
Bill Johnson
jdthefixer
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
