Sony lcd tv # klv-32bx300. working with picture & sound. but lcd tv working in few minutes, lcd tv start get in lot of vertical lines in the screen . few second more get in full screen vertical lines & the vertical lines changing different colour . so what happen to it? how to solve this ? thanks
SOURCE: my lcd tv is cracked
If you mind the lines and if they are too big replacing the screen will be very expensive and there is no way to repair your current display. The way I see it if you pay more 65% of the current value of your TV is too much. You may be able to find a new TV for as much as the repair cost.
SOURCE: Philips LCD model 26TA1000, vertical lines and blank white screen with no picture
it would be easier to find it stripped from a damaged set on ebay.
I see several there but need the part number to search
of course you may purchase that and find it to be the lcd driver.hopefully not.
SOURCE: Vertical colour lines on whole screen
The problem is that the panel has failed. Apparently this is a common problem with LCD TV's between 18 mths and 3 yrs old. If it survives over 3 yrs it is likely to last for a few years longer. The cost of replacing the panel is more than a replacement TV!
SOURCE: I have coloured vertical lines covering my Sony
I also have a 2 yr old Sony KDL32xbr4 that now has multi-colored vertical lines on the screen. I contacted Sony and they say they have "no known issue" of this sort for this model. I find this rather puzzling since I have found numerous postings on the web. They told me to try the factory reset. Whatever. Might as well have said "don't buy a Sony". 2 years! $1300 for a tv and it lasts 2 years! Makes me sick to my stomach.
