This lens is compatible with your Nikon D90 according to this site:
http://lenshero.com/lens/Tamron-14mm-f2.8-IF-Nikon-f-lens
Your complaint "does not work" is rather broad, so I don't know what specific kind of problem(s) your having with it.
If you continue to have issues with it, make sure other lenses work on your D90 to eliminate the body as the source of the problem. Consider performing a 2 button reset on the D90 (and resetting any other customized settings to defaults) and try again. If it still "doesn't work" then contact Tamron to evaluate the lens for possible repair.
SOURCE: Tele converter option for Tamron 28-75mm f2.8
This is a lens for Sony/Minolta cameras. It is not compatible with the Nikon D90. Hence a Teleconverter for Nikon will not work on this lens to mount it to a Nikon D90.
SOURCE: Hi!! The autofocus on
As with almost all camera equipment and lenses I recommend that you do not, under any circumstances try to repair them yourself. Photographic equipment is very delicate and you could just make the problem worse.
The most comprehensive solution would be to contact Tamron itself and send it in for repair. If your product is under warranty you may only have to pay the shipping fees.
You can find Tamron's contact information here:
http://www.tamron-usa.com/contact/default.asp
I hope this information was useful.
Please let me know when/if you get this problem solved.
