I don't know if the security is WEP, WPA, WPA2, WPA Enterprise or WPA2 Enterprise? I need step by step on how to set up the wifi to DSL-2640U router.
SOURCE: issues with my Ipad wifi, IPAD wifi not working
According to Apple, the iPad might not automatically rejoin known WiFi networks using third-party routers that are dual-band capable (802.11 b/g and 802.11 n) when each band’s network uses the same name or use different security settings.
Apple’s recommendation? Try creating separate network names for each separate band’s network (ie: add a G to the end of the name of the 802.11 b/g band) and making sure both bands’ networks use the same security settings.
I'm assuming you excluded the issues desribed in other posts (with being connected to the wrong network) and you actually have a hardware issue. You can always take it to the apple store and demonstrate the problem there, you'll probably receive a replacement. If you have issues with the warranty, there are third party places that will find our what's wrong. If you want to do it yourself, the good news is, it's not too hard to open it. Here is an iPad Repair Guide that shows how to open an iPad. If you want somebody else to do it for you go to iPad Repair NYC.
SOURCE: I had bought an ipad
there were some random wifi issues with ipads early on but the most recent updates through itunes have corrected those. So best thing would be to connect to your computer and make sure its updated. if that doesn't work, may be a range issue, they dont have the longest reception.
SOURCE: my wifi on my iPad
This sounds like a hard ware issue with you wifi antenna. Restore your device using iTunes. If it is still grayed out take it in for service at a local apple store or authorized service provider.
I take it is your own wireless network, so if you look at the bottom of wireless router box usually they have the information required to log on.
If it is your office wireless network contact your system administrator to seek permission to use it and if it is accepatble they will give you the details to log on.
If it is someone else's wireless network connecting to it without permission could be considered theft so we can't really help in this case.
