Question about Timex Triathlon Watches
I need an instruction manual for a timex timt5k575f5 gps watch
The watch doesn't come with a complete instruction manual only a quick start book and heart rate book. I need a complete set of detailed instructions. Where do I get this?
Posted by brian lazarus on
joel nazzir
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 44 Answers
Checkout the available manuals from the link below.
www.timex.ca/en/manuals.aspx
Hope this helps.Thanks!
Posted on Jan 04, 2012
5 Related Answers
Anonymous
  • 135 Answers
SOURCE: SPORTCRAFT Heart Rate monitor watch
Go to:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2016.pdf
Full user manual and instructions there to download.
Please contact again if this in not successful, if it is, your rating would be most appreciated.
Mike.
Posted on Feb 23, 2009
David Shaub
  • 2976 Answers
SOURCE: Timex heart rate monitor does not keep correct BPM. I changed the battery, now the heart rate hovers in the 30' and 40's, never getting to the correct BPM
Make sure the back of the watch is spotless and your skin isn't too dry.
Posted on Apr 23, 2009
Anonymous
SOURCE: inaccurate/intermittent heart rate info?
Here are the things I have noticed that help:
- enough moisture between the HR monitor and your chest. Apply water right before your workout to make sure it isn't all dry between the time you put on your monitor and when you actually started your workout.
- Make sure the strap is tight enough. Mine gets loose over time and the bouncing of running will give me inaccurate readings until I tighten it up again. You can test if this is the problem by using your hands to press the monitor more tightly against your chest - if that seems to fix the problem that a loose strap could be it.
- Use a "conductive gel" instead of water between the monitor and your chest. Conductive gels are pretty cheap.
Posted on Jul 03, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Manual of Timex Zone Heart Rate Monitor watch . Model T5H881F5
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please .
Posted on Apr 14, 2010
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: how do you turn on the heart rate monitor on a
Posted on Apr 20, 2010
What's your problem I need Timex WR-100M manual
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
The WR-100M is not actually the model number of your watch, but rather only an indication of the Water Resistance rating of that particular model (100 Meters) and is found on many different models of Timex watches. You should be able to find the actual model number on the back of the watch under the strap.
Here is a direct link to the TIMEX SUPPORT page where you can download the appropriate USER'S MANUAL for your particular model of TIMEX watch:
http://www.timex.ca/en/manuals.aspx
Just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the complete list of available TIMEX Watch Owner's Manuals for you to download.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you Russ.
Good luck and take care.
Joe.
Dec 01, 2011 | Timex Watches
Instructions for Timex CR 2016 748 L8 (Wanted)
Hi m_cox840,
If you don't have the manual, this is the direct link to all Timex watch instructions/manual:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Hope it helps.
Thank you for using FixYa.
Aug 13, 2011 | Timex Mid Size Sports 1440 Coach Black...
Have Timex Ironman T51081, no instructions, don't
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Jul 23, 2011 | Timex Ironman 53151 Wrist Watch
I need manual Timex Women's T59211
manual download"
May 12, 2011 | Timex Sleek Ironman #T59211 Watch for...
Timex ironman triathalon 100 lap 5F011- need user manual and way to purchase lost gps
manual download"
Mar 10, 2011 | Timex Ironman 100 Lap Triathlon...
I need an owners instruction sheet to learn how to set dATE & TIME.
manual download"
Feb 06, 2011 | Timex Expedition Perpetual Calendar...
Find manual for the Timex Men's GPS watch model T58501
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Feb 20, 2010 | Bulova Watch
Manual for Timex Reef Gear H2Y023
I have a Timex Reef Gear watch...can't find a model number anywhere. (The watch back has the 3 digit code 940, one they don't list on the Timex site).
My watch has two stems to adjust the time, day, date, etc. On mine, you turn the top stem until what you want to adjust appears in the digital window, then you pull out the stem one click to adjust.
Jul 12, 2009 | Timex Watches
Need setting instructions for date,alarm,etc on my timex expedition
http://assets.timex.com/manuals/index.html
Here is the link for all Timex watches and the appropriate manuals.
This should provide you with the information you require, if you have an issue not covered there I will try to find you more specific information.
May 26, 2009 | Timex Watches
I need an owner's manual for TIMEX T54012 watch. It has the gps to measure speed and distance.
Here you will find full instructions:
http://assets.timex.com/manuals/?timexBrand=core
Rate me, please.
Mar 24, 2009 | Timex Ironman 100 Lap Triathlon...
Watches Logo
302 people viewed this question
Top Timex Watches Experts
Janelle Schoonover
Janelle Schoonover
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Are you a Timex Watch Expert? Answer questions, earn points and help others
