Question about HTC Wildfire S Smartphone
Htc stuck in safe mode
How do i turn safe mode off
Posted by paul on
anu kj
    New Friend:
I can't install software's, I have problem with safe mode and one more thing my key button is not working. Get me solution
Posted on Jun 11, 2014
1 Related Answer
ByteGP
Eugene Chetty
  • 45 Answers
SOURCE: My HTC inspire is stuck in safe mode none of my
  1. Turn the power off.
  2. Hold the Volume Down button
  3. Press and hold the Power button until the device turns on
  4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
  5. Select Clear Storage by pressing the Volume Down button
  6. Press and release the Power button
  7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
Posted on Apr 10, 2012
My HTC First is stuck on safe mode and when I try to reboot it the power button or volume down button doesn't work but the volume up button works fine and at the top its say "*** LOCKED***". How do
To get out of safe mode all you have to do is reboot the device, nothing else. The phone should be bale to work fine but without any third party applications.
If what you see on the display is just a bunch of letters, then you are in the recovery section. I'm not sure, but I think that once you highlight a line just tap the Home icon to activate. Make sure that "Reboot Device" is highlighted to reboot the phone in normal mode.
Dec 12, 2014 | HTC Cell Phones
My htc merge is just stucked on blank htc when i turn it on please help me
are you able to get into recovery mode?
With the phone turned off, Hold the 'Volume Down' button and the power button until HTC logo appears and 'Entering Recovery Mode' appears at the top in pink.
If you can access recovery then it could be possible to reset/reinstall android OS
Dec 11, 2014 | HTC Merge Smartphone
Htc one sv stuck in safe mode volume buttons inoperable
Turn off the device. Remove the battery, hold the power button down for 5 to 10 seconds. Reinstall the battery, this should reset the device back to normal. Hope this helps.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/robert_33deecd2f8e91168
Jul 16, 2014 | HTC One SV
Get htc rhyme out of safe mode
How do you turn the HTC RHYME out of safe mode!
Aug 15, 2013 | HTC Rhyme
How to remove safe mode on htc salsa
I dont have a home butten u have to slide it up
Jan 19, 2013 | HTC Salsa Smartphone
My HTC inspire is stuck in safe mode none of my apps show doesn't let me do many things help !
Apr 09, 2012 | HTC Cell Phones
Htc sensation stuck safe mode
This happened to me on HTC Sensation. I was able to get into my apps after a few attempts to reboot seems when volume is all the way down during a reboot it initiates the safe mode. this can happen, im told for many, reasons. Even if your volume controls are working fine.dust etc. although I followed the directions listed above I cleared the htc sense cache then re*stareted and all loaded just fine. I just had too do a little rearanging to my apps on home page . so I am pleased I saved a service call
Mar 27, 2012 | HTC Cell Phones
How do I turn off safe mode on my HTC Explorer?
how do i get the phone out of safe mode
Jan 12, 2012 | HTC Cell Phones
HTC phone in safe mode, can this be fixed
Hi, When you're done troubleshooting problems with your HTC Hero in Safe Mode,
you will need to go through steps to boot it regularly and remove it from Safe Mode.
To do so, turn off the phone. Then while its off, hold the Menu and Power until the phone boots. The Hero should then no longer be in Safe Mode
Start the phone and uninstall apps in safe mode
If your phone keeps restarting, or it starts up but does not display the Home screen, a recently installed application may be causing the issue.
When this happens, try starting up your phone in safe mode. In this mode, your phone does not run any third-party applications. Safe mode allows you to start up your phone successfully so you can uninstall any applications that you have recently installed or which may be stopping your phone from starting up correctly.
To start up your phone in safe mode, press the END CALL/POWER button and hold the MENU button until your phone restarts and displays the Home Screen. You will see "Safe mode" displayed at the bottom-left side of your phone screen. When your phone is in safe mode, follow the same steps in Removing installed apps to uninstall the third-party applications.
After you finish uninstalling the applications, restart your phone and check if the issue is resolved.
Hope it helped.
Thanks for using fixya....
Jan 10, 2011 | HTC Droid Eris by
The safe mode is on how do I remove it
Using the safe mode feature on your T-Mobile G1 will allow you to easily pin point an issue you are experiencing with the device. Follow these steps to enable and disable the safe mode feature.
  1. HOW TO TAKE YOUR T-MOBILE G1 OUT OF SAFE MODE
    If you have found yourself in safe mode and don't know how to turn it off, or if you are finished troubleshooting, turn your device off as you usually would. When you restart the T-Mobile G1 should not be in safe mode anymore.
  2. If the T-Mobile G1 is still in safe mode when you restart, there is something else wrong with your device. At this point you will need to contact technical support to assist in diagnosing the issue.
Nov 14, 2009 | HTC G1
HTC Wildfire S Smartphone Logo
680 people viewed this question
Top HTC Cell Phones Experts
Caltronic TV Repair
Caltronic TV Repair
Level 1 Expert
Marvin
Marvin
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
