Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
KUD 101 JBL0 kitchenaid dishwasher fills with water then just hums. When I hit the cancel/drain button the water does drain.
Posted by dawn chelotti on
shmureimer
    Problem Solver:
  • 7 Answers
Before you go ordering any new parts, have you made sure that the dishwasher is LEVEL. Surprisingly this is a very finicky thing with dishwashers and I even went as far as replacing my float switch before realizing that the dishwasher was slightly out of level. Once I straightened it out the dishwasher was totally fine. Just to be sure, I skewed it in another direction and had the same problem. Like I said, give it a try (front to back AND side to side) and you might be in luck!
Posted on Jan 18, 2012
5 Related Answers
douglas smith
  • 1462 Answers
SOURCE: Dishwasher fill with water then just hums
the hum is probably the main pump powered up but not turning. the pump is an induction motor and a usual fault is the motor capacitor. try to access it, find the value of the capacitor and replace. it is a cheap part
Posted on Apr 02, 2007
reg501
Richard
  • 413 Answers
SOURCE: Kitchenaide KUDM24SE1 dishwasher will not fill with water
It may be the water inlet valve or the electronic control board. To check, remove the bottom toe panel. The valve will be on the left side. There will be live power, so use extreme CAUTION. Start the DW, 1. if you can hear the valve humming or the valve coil is getting warm, replace the valve. 2. Using a device with wires to check the power at plugs, connect to valve power connection, if power is present, replace valve else replace electronic control board.
Posted on Jun 07, 2008
Anonymous
  • 236 Answers
SOURCE: my carlton dishwasher fill and drains but does not wash
sounds as though the wash motor/pump is jammed or has seized therefore no wash.
Posted on Mar 16, 2009
Jeff Meyer
  • 423 Answers
SOURCE: maytag quiet 300 series
The most common solution to your problem is replacing a failed main wash motor/pump.
Without the model number, I can't point you to the correct model number.
Be aware that replacing a wash motor is not a trivial task and most households hire a service tech to do the job.
Good Luck!
Posted on Apr 10, 2009
Anonymous
SOURCE: kenmore elite not washing dishes
Sounds like the motor is stuck. If your careful you can unplug the dishwasher or turn the breaker off, take the bottom panel off and reach in with your finger and spin the motor assembly.
Posted on Nov 12, 2009
Kudi01tj
do you here a hum noise ? trying putting some water in the unit and strat it to see if the motor is running if that works then you have a problem in the fill components there is also a float in the front corner and it might be stuck up
May 24, 2014 | Dishwashers
Kitchenaid DW KUDS30FXSS Cycle starts then I hear a solenoid actuate 4 times then unit goes into cancel drain cycle
Here's a link for the repair manual for your dishwasher:
http://www.appliancerepair.net/kitchenaid-dishwasher-repair.html
Concentration should be on Chapter 2 subsection 2-3 "No Fill"
Then go to Chapter 6; subsections 6-2, 6-3, 6-3a, 6-3b, 6-3c, and 6-3h for testing procedures on relays, actuator valves, etc.
Nov 30, 2013 | KitchenAid KUDS30FXSS Builtin Dishwasher
Gene, I have a Kenmore Elite model # 665
Hey Steve,Sorry it took me so long to answer i was offline and my add is not supposed to displayed when i am off line so sorry about that.
Now then on that dishwasher with the hum and no water circulation it sounds as if the main wash motor is jammed up for some reason it could be that the motor itself is defective or as simple as something such a piece of debris such as broken glass or almost anything caught in the motor causing it to not turn on,by disassembling the wash motor you can see if something is caught in,if nothing is caught in its a (sorry to say) the motor itself thats bad and would need to replaced.The reason the water drains even though it will not circulate is because of the separate drain pump that is working Please reply back after disassembling the pump to check for debris if ya need further assistance.
Thanks for using Fixya.Com,GENE
Oct 18, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
The dishwasher fills with water but then hums. Water will drain if cancel button is pushed.
Sounds like something stuck in spray impeller. Remove spray arm and top of motor pump assembly and clean.
Oct 27, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kitchen Aid dishwasher will not start
Can not start KitchenAid dishwasher..."child lock" light keeps coming on. Help!
Aug 24, 2009 | KitchenAid Dishwashers
Maytag quiet 300 series
Good Luck!
Feb 01, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Jun 07, 2008 | KitchenAid KUDM24SE Built-in Dishwasher
Apr 02, 2007 | Kenmore 24 in. 16039 Built-in Dishwasher
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
268 people viewed this question
Top KitchenAid Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
