Question about Patton Computers & Internet
How to reset patton router 2600 as i forgto ny username and password
Posted by MaqsudHassan on
  • MaqsudHassan Jan 04, 2012
    I Want to Re-Configure it
5 Related Answers
Anonymous
  • 145 Answers
SOURCE: forgot passwrd on a us robotics router
Generally you have to push and hold the reset button, i suggest for 30 seconds, this should completely reset the unit, including passwords and settings.
Posted on Jan 29, 2008
serra_baby
serra baby
  • 144 Answers
SOURCE: standard username and password
hello!
By default the router username is admin, and the password is also admin
Posted on Jul 03, 2008
imp_squared
Joe L.
  • 56 Answers
SOURCE: Broadband Router is asking for username and password
If you haven't setup a username and password on this router before.
Then it's probably using the factory default username and password, for that visit the manufacturer's website.
If you have setup a username and password before on this router, but forgotten what the password is. Give the router a hard reset. How to do that can be found in the manual.
Posted on Aug 14, 2008
Filip Eastman
  • 477 Answers
SOURCE: Don't know the username to "http://192.168.0.1" router Level One.
try username blank if you didnt set any username.also password blank. or if you have set a pass use that. have you changed it from the default ?
only way to get in your router if you dont know your username and password is to reset it.. sorry.
Posted on Jul 06, 2009
Sal De
  • 2699 Answers
SOURCE: I have reset my tw100-s4w1ca trendnet router,but
whenlogging in the user name is admin and there's no password,just hooked one up and this is in the instructions book
Posted on May 10, 2010
I've forgotten my username and password to sign into my ny times account is there another step I can take in order to recover my account and log back in?
You'll need to contact NY Times support to have your password reset. Go online and try to sign in. There should be an option that says "forgot password" and/or "forgot username". Going this route should send a new password to the Email address you used when you created the account.
Aug 15, 2014 | Computers & Internet
Linksys password recovery
Computer Hope does not assist users in bypassing this security measure. If this is your router and you've forgotten the username or password we suggest that the router be hard reset and then setup with a new username and password.
Default username and password
Before doing a hard reset on the router you may want to try the default username and password. While this is not the same for all routers, this may allow you access to your router.
Username: Admin or Administrator
Password: <Blank>, try just pressing enter or try "admin" as the password as well.
If this does not work and you believe the router is using the default username and passwords try viewing the default settings at routerpasswords.com.
Resetting your router
If the default username and password doesn't work it's likely you or someone whose setup your router has enabled a password that has been forgotten. Thankfully most routers will have a small pinhole button on the back or bottom of the router (like that shown in the picture to the right), pressing this button in and holding on this button for 10-15 seconds will hard reset the router. After this has been done setup the router again and enter a username and password that you can write down.
hope this helps
Dec 21, 2011 | Linksys Wireless-G WRT54G Router
How can i find out my pssword.
The default username and password for Linksys routers are:
Username: admin Password: password
or
Username: admin Password: admin
or
Username: <no username> Password: password
If all of this fail you'll need to reset your linksys router so that it will also reset the password to the default. To reset you linksys router you can check it out on this website: http://technicallyeasy.net/2008/01/how-to-reset-linksys-wrt54g-wireless/
Note: Reseting your router means it's going to reload the factory default settings and all of the settings that you made on your router will be deleted permanently.
Apr 23, 2011 | Linksys Wireless-G WRT54G Router
Forgat password
how to change password in grand chase
Apr 03, 2011 | Belkin F5D8236-4 Router
I cant find out my router username and password, please help.
try these...
username: password: (blank means no password)
administrator administrator
operator operator
administrator
(less likely ones)
anonymous
user user
user public
PFCUser 240653C9467E45
If these all fail, reset your router and try again.
Mar 01, 2011 | Compaq (171979-001) Router
Lost my key password for belkin g router
there is a small reset button that u will need to push with a pen. Its usually to the back or side of the router.
Just jeep pushing it until the router resets then use the default username and password.
defaults. (normally)
user name - admin
password - admin
username - Admin
password - admin
username Admin
password Admin
user name Admin
password (blank)
username admin
password blank
look in your manual for the default username and password and instructions on how to reset.
Feb 27, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How to recover the password for 198.168.1.1
You will need to reset it then it will come to default
password. unplug power cable then while powering on press the reset button simultaneously.
ok
A user name and password prompt will appear. Type in admin (lower case) for the username and password. The username and password admin are the default username and password of TP-LINK Routers.
ok link
http://www.tp-link.com/support/showfaq.asp?id=10
Jan 07, 2010 | Computers & Internet
My motorola router is unidentifying my username and password. How do I reset my Username and Password ?
For the motorola router's default username is "admin"; The router's default default password is "motorola".
If it is a Motorola-Cablerouter then default username is " cablecom"; The default password is "router".
Reset the router to Factory Defaults if the password is not working and re-configure it .
Nov 23, 2009 | Computers & Internet
Password
Since you forgto the password the best way to make this router work fine is to reset it and reconfigure it back, To reset it just press and hold the reset button for 15 seconds while the power is ON, then if you still have the setup CD just run and that should take care of everyting, but if you don't have the setup CD you can manually configure it by accessing the router setup page if you're not familiar on how to do that better call LInksys tech support and let one of their tech walk you through with that process they are open 24/7 this is the number 800-3267114..........
Hope that helps............
Sep 16, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
87 people viewed this question
Top Patton Computers & Internet Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Patton Computer and Internet Expert? Answer questions, earn points and help others
