I use a fairy big screwdriver, put end of screwdriver on end of E-clip and strike screwdriver with other hand. May take two or three times. When starting off go to center of clip and pry it off. Its What' for sure.
Hi. This isn't a quick repair. Procedure is to raise wheel off ground, place jack stand in place (for safety), remove brakes to expose axle, remove (4) axle retaining bolts and slide hammer to remove axle. A race removal tool will be needed to remove the old race from the axle shaft. You will buy a new axle seal, bearing and race. NOTE: Press the old bearing off first. There are two sizes plus if the retaining plate or retaining ring get damaged. you won't be surprised. A parts store or hydraulic should be your "Go To Place" for pressing off the old bearing and pressing on, the Retaining plate, new seal and bearing and retaining ring. Clean the axle shaft and install the new race and put it back together. If you need anything else please write back. Details are always good. Don't worry about saying too much. Good Luck.
make sure there aren't any c clips holding it on I would use a block of wood and a hammer I have put green slime in my tires that stuff works great it should fix your tire
CAUTION: The brake drum and hub assembly removal in this procedure is for installing a new wheel bearing, not for access to brake system components.
-All vehicles
Remove the dust cap. Remove the wheel and tire. For additional information, refer to: Wheel and Tire (204-04 Wheels and Tires, Removal and Installation).
-Vehicles with rear drum brakes Release the parking brake. Remove the brake drum and hub assembly. Remove and discard the wheel hub retaining nut.
-Vehicles with rear disc brakes Remove the brake disc. For additional information, refer to in this section.
Remove the wheel hub. Remove and discard the wheel hub retaining nut.
-All vehicles
Remove and discard the wheel speed sensor ring (brake disc shown). Remove the circlip (brake disc shown). Using the special tool, remove and discard the wheel bearing (brake disc shown).
-Installation
-All vehicles
CAUTION: Support the wheel hub assembly on the wheel mounting face and not on the wheel nut studs.
Using the special tool, install the new wheel bearing (brake disc shown).
Install the circlip (brake disc shown).
CAUTIONS:
Make sure the wheel speed sensor ring is not knocked, damaged and kept free from metal fragments.
Protect the face of the wheel speed sensor ring with a non-ferrous flat block to prevent damage.
Make sure the wheel hub or brake drum is adequately supported and do not allow it to rest on the wheel studs..
Make sure the wheel speed sensor ring is pressed on slowly and squarely until fully seated.
Do not exceed a maximum load of 10 kN.
Using the special tool, install a new wheel speed sensor ring (brake disc shown).
CAUTIONS:
Avoid impact on the wheel speed sensor ring.
Make sure the wheel speed sensor ring is clean.
Avoid any contact between the wheel speed sensor ring and a magnetic surface.
Rotate the wheel hub assembly 10 times counter-clockwise when tightening the wheel hub retaining nut to prevent damage to the wheel bearing.
NOTE: Install a new wheel hub retaining nut.
Install the brake drum and hub assembly. Apply the parking brake.
CAUTIONS:
Install the wheel hub retaining nut. Install the brake disc. For additional information, refer to in this section.
-All vehicles Install the wheel and tire. For additional information, refer to: Wheel and Tire (204-04 Wheels and Tires, Removal and Installation).
NOTE: If the dust cap is damaged a new dust cap must be installed.
Using a soft faced hammer and a wooden block, install the dust cap.
There is no real torque settings for the rear wheels, except to say, do not over tighten or you will stretch the lugs and the will loosen over time.
If it is a snap ring then a pair of snap ring pliers are necessary they open the nose when the pliers are closed. see http://www.harborfreight.com/catalogsearch/result?category=&q=snap+ring+pliers
for a description of what you need. They can be purchased at most tool spots.
Before servicing the vehicle, refer to the precautions in the beginning of this section.
NOTE: The wheel bearings are not serviceable. If the bearings are bad, a new hub/bearing assembly must be installed.
Remove or disconnect the following:
Rear wheels
Fig. 1: Exploded view of the rear wheel hub and bearing assembly (disc brake model shown, drum is similar)
Brake drum, if equipped
Rear caliper and rotor assembly from the hub, if equipped
Hub dust cover
Raise the staked portion of the hub retaining nut with a hammer and chisel.
Hub retaining nut and discard it
Hub and bearing assembly from the spindle
Fig. 2: When installing the new hub nut, be sure to stake it into the notch on the spindle
To install:
Install or connect the following:
Bearing assembly on the spindle. Torque the new nut to 131-173 ft. lbs. (177-235 Nm)
Check this GM Chevy Mid-Size Cars 1964-1988 procedure from Repair Guide...
Headlights - REMOVAL & INSTALLATION If some or all of the headlight bulbs being replaced still operate,
refer to the headlight aiming procedure later in this section to ease
checking or adjustment of the headlights after installation.
Disconnect the negative battery cable.
Loosen and remove the retaining screws, then remove the headlight
bezel from the front of the vehicle.
On most models, the headlight bulb retaining ring is only held on
by retaining screws. If so, remove the bulb retaining ring screws. These
are the screws which hold the thin metal ring which holds the bulb
against the adjusting plate. Do not touch the two headlight aiming
screws, at the center of the top and side of the retaining ring (these
screws will have different heads), or the headlight aim will have to be
re-adjusted.
One way to identify the retaining ring screws is that they will be
threaded through a lip on the outer edge of the retaining ring before
threading through the adjusting plate. One the other hand, the
adjustment screws are threaded through the adjustment plate and a spring
loaded holder underneath it.
Fig. 1: Exploded view of a common dual headlight mounting
assembly-1983 Malibu shown typical
Some later model vehicles will use a spring on the retaining ring.
If so equipped, disengage the spring from the retaining ring, using a
cotter pin removal tool, then remove the retaining ring screws.
Pull the bulb and ring forward and then separate them. Unplug the
electrical connector from the rear of the bulb and remove the bulb from
the vehicle.
To install:
Plug the new bulb into the electrical connector.
Position the retaining ring over the bulb, then install the
assembly to the adjusting plate. Secure using the retaining screws and,
if applicable, the spring.
Install and secure the headlight bezel.
Connect the negative battery cable.
Loosen and remove the headlight bezel retaining screws
Make sure all of the screws are removed, then pull the bezel from
Loosen and remove the retaining ring screws
Pull the retaining ring and bulb forward to separate them
Unplug the electrical connector from the rear of the headlight
Loosen the wheel hub nut. Remove the front road wheel and tire. Remove the tie rod end retaining nut. Using the special tool 204-192 Ball joint Splitter detach the tie rod end. Remove the subframe reinforcement plate retaining bolts. Loosen the subframe rear mount bolt. Loosen the subframe front mount bolt. Remove and discard the wheel hub nut. using spcial tools 204-269Forcing Screw,205-491-01 adapter nuts,205-491 wheel hub puller Detach the wheel knuckle. Remove the lower arm ball joint retaining bolt. Reposition the lower arm. Detach the wheel knuckle. using special tools 307-443 RH Halfshaft splitter ,307-442 RH Halfshaft splitter handle detach the halfshaft. Remove the exhaust muffler inlet pipe. Remove the halfshaft seal. Remove the transfer case Y bracket retaining bolt. To prevent damage to the transfer box internal seal, make sure that the link shaft is not retracted further than 200 mm from the transfer box casing. remove the halfshaft. Attach special tools to the halfshaft. Lever the special tools to displace the halfshaft. Install the transfer case Y bracket retaining bolt. Remove the halfshaft. Use suitable protective covers to protect the barshaft. Remove the halfshaft snap ring. Install a new snap ring to the halfshaft. Install a new halfshaft seal. Remove the special tool. Remove the transfer case Y bracket retaining bolt. Remove the special tool. Make sure the CV joint splines are located fully. Do not use excessive force when engaging the CV joint into the link shaft. Install the halfshaft. Install the transfer case Y bracket retaining bolt. Tighten to 25 Nm. Attach the wheel knuckle. Reposition the lower arm. Attach the wheel knuckle. Install the lower arm ball joint retaining bolt. Tighten to 83 Nm. Install the exhaust muffler inlet pipe. Tighten the subframe front mount retaining bolt. Tighten to 142 Nm. Loosely install the subframe rear mount retaining bolt. Install the subframe reinforcement plate retaining bolts. Tighten to 35 Nm. Tighten to 142 Nm. Install the tie rod end. Tighten to 35 Nm. Loosely install a new wheel hub nut. Install the front road wheel and tire. Tighten the wheel hub nut. Tighten to 330 Nm. Check the subframe alignment.
